Quick t-case Q
Started by Talon84x4, March 04, 2007, 09:10:11 PM
Talon84x4
Can I leave the detent pin out from between the shift rails with a normal shifter?
Reason being, I just finished building my 4.7 case and am wondering if I should go back and take it out while I still can before I seal it up. Just incase I want to do twin stick or a custom tripple shifter in the future. If I can leave it out and everything will work fine, that would be great.
Thanks for any info  :biggthumpup:
Talon V.
Low & Slow 84 PU - http://board.marlincrawler.com/index.php?topic=31982.0
Central Valley Crawlers
inmyownsummerami
You can leave it out, there's a lot of guys that run without the interlock pin.
WHITE WHEEL ROCK CRAWLERS "If your wheels ain't white, they ain't right"
:greengrin:My 1st Gen. Toyota SAS (2wd to 4wd) :greengrin: (In Progress)
RIP "Goody Goods" My DDW Brother
Talon84x4
Interlock pin, I knew I called it the wrong name, and after reading those instructions 10 times, figure I would remember what it's called  :slap:
Thanks  :gap:
