material of input shaft on 21 spline t-case??!
Started by junkyard joe, March 05, 2004, 09:27:27 AM
junkyard joe
i am doing a failure anaylsis on the rear input shaft of my 21 spline toy case for a materials class, it would help a bunch if somebody would know the material that the shaft is made out of any help would be much appreciated
joe
sammy, 4.3,th350,dual toys,4.11 toys, 39.5 boggers, 38 swampers, if your not living on the edge you are taking up too much space!
84runner
junkyard joe
well thats actually why i posted here i was told on pirate that marlin would know soooooooooo............
well thanks in advance
Marlin
Joe, after having problems with the factory, 21 spline inputs failing, back in 97', I sent one to a lab to have it checked out....
It costs me about $100.00 to have it complety checked out.
As i remember, the closest american alloy was 1050, or 1051.
This is a tool steel, and is case hardened by adding carbon.
I still have the results some where.....
MC
84runner
Sounds like Marlin is doing people homework now. This guy can do it all  :yupyup:
junkyard joe
sweet thats what i was looking for, the way the grain looked i suspected that it was carbonized, if it would not be to much work could you post that report?
thanx
joe
