84 toyota 4x4 on 3/4 ton axles!!!!!
Started by ToYocRawleR, February 18, 2007, 09:15:52 PM
ToYocRawleR
84 toyota 4x4
Has carbuerated 22r runs strong doesn't burn oil.
This truck has 14 bolt rear axle welded with 4:10's
dana 44 front welded with 4:10's
All 8 lug.
Has custom spring pack in front with sky manufacturing fullwidth axle swap kit.
Has mix matched rims all are 16.5x 10 with 39.5x15" TSL's
Rear has 63" chevy with double shackle and 3" block
All stainless steel brake lines $150
Dedenbear knuckle $200
Brand new WARN premium locking hubs. $100
Bilstein shocks with the 5150's up front. $350
Tube shock hoops
high steer with 1 ton rod ends $200
custom machined drive flange on the 14 bolt...only one in existance cost $300, so you can run toyota driveline.
Dual transfer cases with 23 spline 4:70 gear in rear case. $800
high angle rear drive line in rear with dual cv. $175
Square front driveline.
Front fender are cut out, bed is bobbed and dovetailed.
LED taillights $90
Truck has dents all over.
Can throw in a 91 cab and bed if wanted.
Needs a few things nothing major. Call or email if interested.
[email protected]
530-877-1200
I also have a 22r motor with about 60,000 miles on it that i might throw in if the price is right. It has a trd cam in it and thorley header. Also comes with a weber. Or will sell for $550. Thats what i paid for it.
Rigs:
05 F-250 Powerstroke
93 RunneR ...Build-up  http://board.marlincrawler.com/index.php?topic=85644.0
fortysixandtwo - I drove through Dunsmuir once I dont think anything there is "super nice"
Just kidding man. I guess there is, its your bed
Lizard_lips
The statistic on sanity is that One in every four is insane, Think of your three best friends if they're ok then its you.
abriel68
how big of a lift do those chevy springs get you?
ToYocRawleR
Clears the 40's no prob.  They are like 4in plus 3inch block plus about a 6-8in shackle.  Its plenty of lift.  It would clear 42's
Rigs:
Lizard_lips
indeed it would. Is that other cab in good shape? whats all included in that? I was thinking about swapping a newer cab on my old truck
ToYocRawleR
The cabs Hella clean and pretty much complete its missing grille fenders and hood.  It was a 2wd.
Rigs:
JoeShmo65
i might have missed it but how much did u want for that truck?? and where are u located???
"what was that daddy?"..."Don't worry honey, just a jeep i used for traction, now go back to sleep."
ROFL
ToYocRawleR
I ended up parting it out and cutting it up with a plasma cutter
Rigs:
Lizard_lips
ToYocRawleR
Steering wheel, cluster, shocks, radiator. Thats all i can think of right now.  I got another project going though that will aquire these parts eventially.  Hopefully before july 6th cause abunch of us are planning on going to the rubicon then.
Rigs:
Lizard_lips
toyotaexo
ToYocRawleR
High steers gone.
Im building an 85 2wd ex. cab.
I have 94 fj80 axles going under it and im probably gonna go with some 39.5 iroks.
Rigs:
Lizard_lips
do you have any of the suspension left from that truck?
ToYocRawleR
No i sold it with the axles.  Im gonna run T100's in the rear with a double shackle, and TG 5" springs in the front.  Im trying to get one of those mc10 chain drive adapters for my case setup.
Rigs:
