What wrong with my IDLE!!!!!
Started by max, February 29, 2004, 04:33:04 PM
max
Ok heres the story,
I have a 89 4runner w/ 3.0L V6.  It is supposed to idle at 800rpm.  It would cycle though staring at 800 rpm go up 1000 sputter and drop back to 800 rpm.  Little putts could be heard from exhaust It runs good.  There was no engine light.  Couldn't find any vacume leaks and I replaced pcv valve.  I adjusted the Trottle Position Sensor and it fixed it.  Couple days ago I cleaned my K&N air filter and the idle problem started, the TPS won't make it stop, it is only going up and down about 50 rpm, but little jolts can be felt at stop lights so I want to fix it, any ideas!!!!!
Does it only surge at stoplights.  Maybe just in or out of gear?
WT
max
It seems to have gotten better, however I have always have noticed If I hit my gas hard the engine sounds slugish, it accelerates faster if I graduly give it gas, are all the old toyota engines this way.  I think the k&n air filter just let to much air in
Josh
Marlin
It still sounds like your truck is going in and out of base idle. Are you sure that the throttle position is properly adjusted?
Does the timing change when the engine speeds up and slows down?
Is there a change when the connector is shorted for the base timing?
MC
84runner
When I hear a car that idles like that first thing I think is fuel service. clogged injector of filter.  But you also said you cleanded you K&N. Did you let it fully dry before you installed it?  That oil could be fouling out a plug
RustyToy
did you check your intake... my truck did the same thing with a intake leak....
gferris5
You know what has caused a number of my bad idles? It sounds silly, but a number of operations have required me to move my throttle cable, and then when i put it back, I re-connect it, but I don't route it correctly, thus providing too much friction-and wreaking havoc on my driveability. As cheap insurance, go ahead and lube up the throttle cable. See what happens...
yotaboy79
sounds like ur tps is shot might need a new one
max
#9
Thanks for all the input.  Throttle cable could be prob, the truck has 214,000 miles.  Now I sound like an ass, When I washed my K&N It said not to heat dry it so I don't care because I am getting new truck soon and just got the hairdryer out and waved at it a little.  I didn't mess the cotton media up but I did put it back on still wet, NOT DRIPPING.  The TPS went bad about 5 months ago, could it be bad again it was genuwine toyota from stealership.  Guess it could be gas filter to.  Thanks every one and Marlin I will check timming.
max
#10
MARLIN RULES!  Thanks man, I had my timming advanced to 15' before from previous idle problems.  Well now my engine is alot queiter, I jumped the E1 and T1 and adjusted timming to STOCK, 10'.  took out the jumper and it went to 8'.  Then I adjusted the screw on the trottle, and adjusted the TPS.  Runs better now, idles close to as good as it ever did, doesn't lose alot of power on hills.  Thanks marlin
Marlin
#11
Glad to hear you got it worked out :_order:
Every now and then we get lucky :beerchug:
MC
max
Well I will have my new truck soon so as long as it keeps running I can trade it in 215,000 miles.
