Author Topic: Reputable Turbo shops  (Read 2711 times)
4WDJOE
  • Member since Dec '06
« on: Feb 10, 2007, 03:10:02 PM »
Well I'm in the process of a full rebuild on my 87 Turbo Runner, but I'm not having alot of luck with finding a place to rebuild my Turbo. Does anyone have a shop they'd like to suggest? I really appreciate any help, thanks.
87 Turbo 'Runner, 32's, 1" BL
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
Re: Reputable Turbo shops
« Reply #1 on: Feb 10, 2007, 03:23:34 PM »
dont waste  your money  on the stock  ct20 turbo
go  find a ct26  from a supra,  easy  mod  and MUCH better
« Reply #2 on: Feb 10, 2007, 03:27:01 PM »
just about any  turbo  is better than the  one that came stock  on the  trucks,  :headshake:
dont  pay  somebody to rebuild  what was junk to begin with
dcg9381
  • Member since May '05
« Reply #3 on: Mar 17, 2007, 11:26:52 PM »
It's not a junk turbo.. How many mid-late 1980s turbos can make it over 100k miles?
It was a turbo hooked to a hard line exhaust system (no flex tube) -so it tends to crack.
Performance wise, it's a bit on the small side.
Talk to guys at the gpop shop about rebuilding it.  If it's cracked (exhaust side) hold on to your wallet.
Consider a CT26 (requires some modifications) or a t3 instead.
eightyfive
  • Turtle Points: 232
  • Male Posts: 552
  • Member since Dec '05
« Reply #4 on: Mar 18, 2007, 05:40:24 PM »
i also suggest a T3, not from experience but from research.
._________________________________________.
||____________||____________||___T0Y0TA__||
||____________||____________||____________||
1985 TOYOTA 4RUNNER
some modifications here and there....
RAZOR
  • Male Posts: 143
  • Member since Oct '05
  • It's all about the LongFields
« Reply #5 on: Mar 19, 2007, 09:56:10 AM »
My new truck has a T3 that suppose to go in a sabb. Works great and everyone looks when you let off the gas because it sounds like a big turbo diesel. Good Luck!  :biggthumpup:
Finally Straight Axled, e-Locker, 5.29's, Lockright Rear, 13" travel tractor spline driveshaft, CV eliminator, Fully Gusseted front axle, Marlins almighty 5" Trail Flex lift Kit, 36" TSL's
In Marlin Crawler, I trust.
If you got the Nuts, Follow my Ruts!
Lift It, Fat Chicks Can't Jump!
Motocross, Because it Requires 2!
dcg9381
« Reply #6 on: Jun 29, 2007, 01:56:43 PM »
the saab t3 is .42/.48.  Very common.. I've run one also -- great choice for a stock 22rte.
RAZOR
  • Male Posts: 143
« Reply #7 on: Jul 02, 2007, 08:28:58 AM »
What do those numbers mean? I am new to the turbo side of things....
  • Turtle Points: 2872
  • Male Posts: 8,707
  • Member since Sep '05
« Reply #8 on: Jul 02, 2007, 08:32:16 AM »
not sure what the decimaled numbers above mean...
but ct26, ct20, t3 are turbo models.. the t3 is a garrett, the otehrs are toyota... the ct20 came on the 22rte, the ct26 came on a supra with a 7mgte
robrub00 is going to run a ct26 on his 4runner
madhunt
  • Turtle Points: 52
  • Male Posts: 490
  • Member since Apr '06
« Reply #9 on: Jul 02, 2007, 09:54:06 AM »
main turbo in visalia is very good they do from car to truck to airplane.
HIGH AND TIGHT OFFROAD
dcg9381
« Reply #10 on: Jul 15, 2007, 09:08:02 PM »
The numbers are the "AR" ratio on the turbo.  Do a basic google search for:
"turbo" "AR" "trim" - you'll find a page that gives the detail.
A smaller AR means a quick spooling turbo.  A larger AR means slower spooling, more top end.
Last post Feb 19, 2005, 08:11:26 PM
by Hyena
Last post May 31, 2010, 11:36:25 PM
by fade
Last post Jan 02, 2017, 02:33:24 PM
by jbramble24
Last post Apr 27, 2014, 04:39:13 AM
by jimbo74
Last post Jan 20, 2014, 09:42:59 PM
by ToxicGumbo
