I've installed a few e-lockers, I tried to use the factory studs the first time and it was a PITA. I always use bolts now. You want M8 bolts that are 100 mm long, my local Ace Hardware had them.
when you say reverse rotation is that the hi pinion with reverse cut gears??? or do the elockers come reverse and regular??
do you put the bolt head on the inside or outside? what grade did you get the bolts at ace?
Started by robrub00 Toyota Pickup/4Runner Tech 1979-95
Started by snowplow Toyota Pickup/4Runner Tech 1979-95
Started by Johnny5 Engine
Started by peacesells Engine
Started by Pillowpants808 New Member Check-In!
