I have a 91 22RE 4X4. Many months back my right side turn signal started to act funny, occasionally it would blink fast as if there was a bulb out and then start working normal. So I checked and replaced any bulbs and made sure the sockets were good and clean. Months down the road the signal will constantly blink at a faster than normal rate. No blown bulbs. So add a few more months and some more observations to this. When the brakes are applied my turn signal blinks even faster, the problem can be more prevalent when the parking lights are on. So add few more months, (rode my motorcycle all summer didn't need the truck) now things get worse. When I press the brake both my back up lights iluminate dimly, as does the right turn signal, and the right parking light appears to be on and the brake light appears to be off. I am under the assumption that I have a bad ground somewhere. I need to know where the lighting grounds are. None of the wiring diagrams I have access to tell where things like that are. I tried a different combination switch just for fun since I have one and that didn't help. Any insight or any good wiring diagrams?
Thanks
Andrew
