MAS modifications
Started by lowgeared, February 24, 2004, 03:35:06 PM
lowgeared
What exactly are they doing when they open up the top of the box on the mass airflow sensor?  My 85 efi pickup and 85 4runner were both screwed with before I bought them.  Just wondering what they did in there??   ???
gferris5
Underneath that little cover is the pre-programmed fuel curve for the 22re, physically moving the wire a tooth over will have the perceived effect of richening up the mixture-what its actually doing is richening the mixture sooner in the curve. As the butterfly valve swings open, the little dial in the box also swings over the fuel map, as it swings, it sends a message to the comp to send fuel, moving the wire over, puts it later on the fuel curve, but earlier in the mechanical swing of the butterfly valve. Or at least that's how I understand it. It's also not very warranted on a stock breathing 22re, too much can actually decrease hp. Have fun.
