Author Topic: 3.0 fuel pump problem how do i fix or check if it is working.  (Read 1265 times)
yotadork83
  • Turtle Points: 18
  • Male Posts: 705
  • Member since Mar '06
  • ninja turtules rule!!
3.0 fuel pump problem how do i fix or check if it is working. i took off the feul filter to see if it is cloged or not and its not so i turned the key on to see if the pump is working or not and i had no pressure so i want to know how to see if it works or not other than that.
yotas 4 life homie!
Plowking
  • Turtle Points: -75
  • Male Posts: 504
  • Member since Jan '05
  • Awesome yota
    • Buy me a drink
Check for voltage at fuel pump turn key in on position and disconnect fuel pumps wire set. install test light or meter over wires. Than either turn key to start position or leave key in on position and stick something in mass air sensor box to open up that door (right behind air filter) when that door is open it will send juice to the fuel pump. Start there.
2008 Dodge Diesel  (Cummins Rule)
6.7 manual quad 8 foot bed H&S delete, banks air box
93 yota 3.0 locked up...
2004 Yamaha Raptor 660R
Plowking
  • Male Posts: 504
  • Awesome yota
    • Buy me a drink
Sorry if you have juice it is more than likely the pump is bad. Did you check the inline fuel filter for a clog?
yotadork83 [OP]
  • Turtle Points: 18
  • Male Posts: 705
fixed it turns out that the previos owner cut the wire and didnt crip both wires togther so that he had some kind of security system.
yotas 4 life homie!
Last post Mar 31, 2005, 07:34:15 PM
by alwayzbroken
Last post Mar 31, 2007, 09:35:41 AM
by robrub00
Last post Jun 24, 2007, 09:41:07 PM
by speedemon
Last post Apr 02, 2008, 08:35:42 PM
by 79coyotefrg
Last post Jun 19, 2008, 02:48:39 PM
by ROKTOY829
