V6 Adapter
Started by Elvota, January 24, 2007, 08:10:07 PM
Elvota
I have a line on a dual crawler setup, 23 spline 4.7 in the rear case.
As it sits now, there is a 21 spline shaft sticking out of the front transfer case.
Will the V6 adapter (30-4GT) work, or do I need to change the front transfer output shaft to a 23 spline with Marlin part number MC-14211 and also get the V6 adapter?
Having no luck during the day with the Marlin phones.  Guess it's a good sign they are so busy.  :thumbs:
yotadork83
you awnsered your own question i think. what is your vehicle specs, it's sounds like you have 3.0 and manual transmission if so you will need to get the v6 adaptor plate and a 23 spline input for the front case. if you go that route make sure you make clearance for the shifter rods its a pain removing the xfer case a bunch before you figure out whats actually wrong.
yotas 4 life homie!
