What carbs will fit a 20R
Started by heep70, January 22, 2007, 05:01:43 AM
heep70
What other carbs will fit a 20R besides a Weber?  Thanks
Greg
1971 F250 "Highboy".
1986 Subaru wagon 4X4.
1980 Toyota
Bloomcounty
Get ya the adaptor from LC engineering and put a 22R carb. on it  .
yep,  a 22R  carb  is a big  upgrade for power on a 20R,  same cfm  as the 3236 weber
punkrock crawler
How can you tell the difference from a 20R carb vs. a 22R carb?
Dying to live and living to die!
1983 Hilux
3" suspension lift, Marlin L52 transmission, Marlin ultimatecase 4.70, Marlin 1200 Clutch, 30" tires, Spraypaint exterior, Webber carb.
2006 Tacoma 4x4
they are different entirely, the 22r is squarish and the other is rounded
punkrock crawler
Ok, good I have the 22R type. Now I just need to find a good place to get parts from. Thanks
1983 Hilux
2006 Tacoma 4x4
heep70
I thought the 22R would bolt down to a 20R manifold.  Also, What about all the vacum that the 22R carb has on it?  Alot of the vaccum on my 20R has been removed.
Do you have a diagram of which vac lines are needed to run the 22R carb?
Greg
1980 Toyota
heep70
Greg
1980 Toyota
punkrock crawler
Thanks for posting up the kit. I already have the 22R carb and manifold. As far as a vacuum line diagram I dont have one. There is some info in the Hanynes Manual and Factory manual. That should help. I do know that on my whitch has all the smog equip removed I only have a few lines.
1983 Hilux
2006 Tacoma 4x4
