1986 toyota p/u SAS
Started by 86gatoy, January 20, 2007, 09:52:15 PM
86gatoy
deciding to sell my rig now because i need something very reliable, as i am a high school student now and this truck is not becoming what i really need..
1986 toyota p/u
22re (converted to a 22re before i bought it last year)
5spd, top shift case
new slave cyl.
YUKON 5.29s (need to be set up) (front needs to be re done, i am not proficient at gear installs, but has not been driven)
spool for the rear and a solid pinion spacer
SAS
81' LC rotors
trail-gear 26'' brake lines
trail-gear hanger/shackle kit
trail-gear high steer
trail-gear pitman arm
pro crap 4'' front springs
52'' F150 rears
bucket seats
new head gasket
new water pump
timing set was done in febuary of 06'
new computer
new fuel pump
new starter
new starter relay
new battery
new alternator
new belts
new NGK plugs /plug wires
new airfilter
new battery cables/terminals
old bald 35'' mickey thompson baja claw radials
15x8 chevy rallye wheels
-- i have receipts for all this except head shave job, since my step fathers nephew works at a race shop and had the machine shop do it)
thats all i can think of for now
and :
the down side :
it has not been started since august (pulled motor for build)
needs a windshield
needs to be started
needs the gears set up
needs the rear drive shaft lengthened
needs a front drive shaft made
might need a new front housing (this is kinda warped, from when the trusses were welded on)
i would like to get $2000 for it for the $1800 i've put into it, and my work..
[email protected]
located in cumming, ga
86gatoy
