Shifter
Started by RedneckRyderI, February 19, 2004, 10:01:42 AM
RedneckRyderI
i need instructions on how to split the shifting rails on a NEW PROCESS 205 transfer case so i can have 2 shifters and select high and low range with one and 2 and 4 wheel drive with the other ?
I have an article that covers that.  Ill see if I can find it this evening..
WT
RedneckRyderI
I am trying to build a custom truck and I'm planning on using a doubler kit for the transfer cases. I am going to run is a stroked 454, turbo 400, chevy NP 203 and ford NP 205. I realize I'll probably have to use two seperate shifters, since they are on opposite sides.
I'm hoping if i can find some instruction that I might be able to fabricate them myself but i still need to know how to make the 205 shift independently
Any ideas or help you can give me would be great.
Marlin
#3
Offroad Design in Carbondale CO would have the answer. They make a doubler for the 203/205 t-case. I will post their #. I have it at the shop.
MC
 :biggthumpup:I found the article! here goes.
next
