How Long??
Started by cmc86, February 16, 2004, 10:32:14 PM
cmc86
I have a W-56 that the P.O. put in. Unknow milage. The bearings are whinning in 4th and 5th. I does it the most on the coast side. How long do I have to put this off. This is my DD. I drive about 70 miles a day.
hmm....
Marlin
Change the oil and check for build up on the magnet. I use 80/90 GL5 gear oil. There is no way to know how long it will last. The best advise is to use 4th as much as possible, and stay out of 5th gear, this will make it last as long as possible :crossed:
MC
cmc86
Ok, thanks. Changed the oil and put sythetic in about three months ago. There were no excessive shavings on the plug, and I have been try to lay off 5th.
hmm....
