its on its way to rebuild landbut you have a while to save money
Your center plate is worn out and also a couple of your bearings are worn out. These two combine to allow the mainshaft to "walk" or move forward or rearward depending on the direction of the load, and since the mainshaft is moving but the shift fork is not, the movement drags the mainshaft under the shift collar/hub thus disengaging the gear.After you notice this in 1st, as it gets worse, I believe it will also begin to pop out of 3rd gear also.The only way to fix this is the replace the worn out parts.BigMike
I better save my . Anyone know who sells good rebuilt transmissions?
Started by jamesyz250 Toyota Pickup/4Runner Tech 1979-95
Started by stahld Toyota Pickup/4Runner Tech 1979-95
Started by matttottensr General 4WD Discussion
Started by Prospectors77 Newbie Questions
Started by Moose404 Transmission/Clutch
