rear axle indexing
Started by mickeyfinn, January 08, 2007, 03:45:29 AM
mickeyfinn
need to know how far the rear axle can be turned without oil starvation. is there a general rule. is there somewhere on the marlin board i can get more info.
FIREBALL
Is this daily driver? I've seen them turned up pretty far without problems, so my first inclination is yes, go for it, but i'm currious how far and how much driving highway speeds etc.
Gittinit
You can alwayse fill through the breather hole or relocate the fill plug to get more capacity in the diff.
my favorite places:
http://www.flatnasty.net/
http://www.orvpark.com/
FIREBALL
Sammy? How far do you need to turn it up?
FIREBALL
Unless you've got something really freakin wierd in mind you will be fine with what ever angle you set up. With driveline length and that amount of lift it probably won't need much rotating anyway.
mickeyfinn
i was thinking the same way. my biggest concern is the pinion starvation. i am going to talk to one of the driveshaft guys and see what they think.
Gewehr43
How many degrees were you thinking?  I have been thinking about doing the same thing on my '82 longbed
fordh8r
  :attention: The few degrees that you'll turn your housing won't affect the oiling of your pinion bearings since there is a large opening above the inner pinion bearing to allow oil slinging off the ring gear to constantly fill that cavity and lube the pinion bearings.  :biggthumpup: As long as the ring gear is submerged in lube you should have no problems.  Unless, of course, you tilted it way up the oil would run out of the pinion area faster and may minimize oiling some,  but not completely.  :twocents:  :crossed:
