Author Topic: V6 Diff into 4 Cyl Housing?  (Read 2088 times)
Matty
  • Turtle Points: -18
  • Male Posts: 875
  • Member since Jul '05
« on: Jan 07, 2007, 09:33:25 AM »
so i have my 85 4cylinder rear housing and im trying to put a V6 diff into it, but it seems as though its just a hair too big.  is that the case?  can v6 diffs not go into 4 cylinder housings? or is it cause its a pre IFS housing?  maybe im just being stupid
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
Re: V6 Diff into 4 Cyl Housing?
« Reply #1 on: Jan 07, 2007, 09:37:15 AM »
it will go in just fine  ,  just get  it  in the "right" spot  and it will  go in, i had to rotate the pinion  for my elocker  but it will
assuming its not a 8.4  inch  diff from a tacoma
gotrocks
  • Turtle Points: 107
  • Male Posts: 2,653
  • Member since Dec '04
  • FLOOR IT!!
« Reply #2 on: Jan 07, 2007, 09:37:51 AM »
I have a V6 in my front 85 housing and it fits just fine.  I'm running 5.29's (not that the gear ratio should matter I think) and it fits.  How long did you try and slid it in?  If I remember right its pretty much just the pinion thats stronger.  The ring gear is still an 8" ring gear but just a tad thicker.
Matty [OP]
  • Male Posts: 875
« Reply #3 on: Jan 07, 2007, 09:39:41 AM »
yea mines 5.29d too.  i tried for a while.  it really seems as though because the ring gear is thicker that it is getting hung up
gotrocks
  • Male Posts: 2,653
  • FLOOR IT!!
« Reply #4 on: Jan 07, 2007, 09:45:29 AM »
hmm well where is it hitting?
Matty [OP]
  • Male Posts: 875
« Reply #5 on: Jan 07, 2007, 09:46:51 AM »
the ring is clipping the top and bottom at those notches.  on the teeth side just seems like the notches are too small
gotrocks
  • Male Posts: 2,653
  • FLOOR IT!!
« Reply #6 on: Jan 07, 2007, 09:50:34 AM »
well worse come to worse just trim as littl as you can off until it fits.  Remember you can always cut more but its a lot hard to put it back on.
Matty [OP]
  • Male Posts: 875
« Reply #7 on: Jan 07, 2007, 07:31:43 PM »
after a long time of trying to no success i ground down a little bit on each notch and that bastid slid right in.   :thumbs:
gotrocks
  • Male Posts: 2,653
  • FLOOR IT!!
« Reply #8 on: Jan 07, 2007, 10:13:28 PM »
glad to hear
Prismo
  • Turtle Points: 8403
  • Member since Oct '03
  • Living in the green house
« Reply #9 on: Jan 07, 2007, 11:20:47 PM »
Just saw this. I had to grind my housing a bit also when putting in the v6 diff w/529 gears.
V-Man
  • Turtle Points: 29
  • Male Posts: 792
  • Member since Sep '04
« Reply #10 on: Jan 08, 2007, 03:43:59 AM »
 I think the 8.4 carrier is only in the tundra. ring and pinion is the same as the 8' diff, but the carrier if not.
Last post Dec 18, 2006, 06:22:29 PM
by DTB
Last post Apr 25, 2007, 11:48:51 PM
by NT-OUTBACK
Last post Nov 11, 2007, 05:48:10 PM
by 79coyotefrg
Last post Feb 23, 2009, 01:59:14 PM
by Bazzi
Last post Mar 26, 2011, 08:12:34 PM
by Bullrout
