Author Topic: crank pulley rotates and binds in either direction  (Read 1657 times)
4rox
  • Turtle Points: 115
  • Male Posts: 122
  • Member since Apr '04
  • Crawling in texas
« on: Dec 25, 2006, 06:37:09 PM »
I have an 89 4runner with the 3.0 that has been sitting for awhile.I start it periodically and then one day it seemed as if the starter locked up.Pulled the starter and try to rotate the crankand it binds up in either direction.I then yanked the plugs thinking maybe it jumped time with the same results.The truck ran fine the last time I ran it.I let it run for at least a half an hour with no odd noises whatsoever.I hear a clicking noise around the flywheel if I rotate it past where it binds.All the bolts in the flywheel are tight.What gives?
I'd rather push a Toyota than drive a Jeep!!!
6.72:1
  • Turtle Points: 73
  • Male Posts: 1,856
  • Member since Mar '05
  • Stuck with 2.5ton Rocks....
Hmmm....
mrkupfer@gmail.com
Cell: (205) 919-3290
www.Kupferphotography.com
sounds like you dropped a valve,  pull your  valve covers  and see if a spring is loose and wobbly
4rox [OP]
  • Male Posts: 122
  • Crawling in texas
It ran fine the last time I started it and didn't miss,sputter,or smoke and the plugs looked good.
Last post Dec 30, 2005, 04:57:16 PM
by DTB
Last post Mar 16, 2006, 05:07:32 PM
by Hyena
Last post Dec 12, 2019, 02:20:00 PM
by vic and mikes
Last post Dec 12, 2019, 02:47:38 PM
by vic and mikes
Last post Jul 21, 2021, 06:27:38 PM
by Burl
