I INSTALLED A G52 IN TO MY 83 YOTA AND WONT SHIFT IN TO 1ST OR 3RD IT SOUNDS LIKE WHEN I SHIFT LIKE THE GEARS GRINDING AS THOUGH IT DOESNT GET SHIFTED FORWARD FAR ENOUGH SO I DRAINED THE GEAR OIL AND LOOKED FOR METAL IN THE GEAR OIL THERE WAS NONE BUT THERE WAS SOME CHIPS OF METAL ON THE PLUG NOTHING BIG BUT SOME NEED SOME ANSWERS IF ANYONE COULD HELP ALL OTHER GEARS WORK PERFECT NO LOUD NOISES COMING OUT OF TRANI OR NOTHING HELP
1st Pull the shifter and check if the shift seat and shift ball is in good condition. If these are worn/missing, it can cause bad shifting.2nd. Body lift? Maybe the shifter is hitting the pan. Remove shifter boot and verify if shifter is hitting metal.
Glass?
yeah but he said that u cant really know untill theres a load on it
thanks for the info guys pulled off everything wasnt hitting the pan took it to trani guy yesterday some how glass ended up getting in it and got caught between gears everything was fine just cleaned it up and resealed no damage to synchros or gears
im guessing your "tranny guy" is taking you to a cleaning, probably charged you for pulling the tranny apart while he had a cup of coffee
Started by Cheesemaker « 1 2 » General 4WD Discussion
Started by Jaysen Toyota Pickup/4Runner Tech 1979-95
Started by luvyota Engine
Started by tyesman Engine
Started by Mudder Transmission/Clutch
