w56 to a g52?????????????????HELP
Started by stone4x4, February 10, 2004, 10:56:59 AM
stone4x4
i have a stock 86 efi yota the w56 needs building
i have a g52 onthe ground
will the g52 shifters lineup in my cab???
it would only be temp till i build my w56
any help would be great :bowdown:
GOD MADE DIRT AND DIRT DON'T HURT
gferris5
Hey, I did that same thing. Still want to know the answer...well, I guess I'll share..
The shifters will line up, although first and second gear will put the shifter right next to your leg-it's comfy though in a way, and any lanky friends in the passenger seat will have enough leg room so you don't have to push them out of the way to get 5th gear. There are some mild difs in gearing, and supposedly the 52 is a little weaker, but other than that, the only real difference you'll notice is the strange shifter position that requires you to cut a smidge out from the front of the original hole-or at least that's how my bucket seated 4runner was, if you have the bench seat that the 52 was designed for, you might be able to avoid cutting. And its not much cutting at that. :driving:
gferris5
Oh, you'll need a marlin shift knob, it's much more comfortable in the thumbs up position that makes the 52 more comfy in the hand when you're rowin the gears.
Marlin
#3
Since the G52 was made for a bench seat truck, and the W56 was made for a bucket seat truck, the trans and t/case handles will be about 2" forward.
You will need the G52 trans handle as well, it is a difference style and will be aiming toward the passenger. (Your W56 trans handle aims toward the driver). So your factory boot will not work, unless you find a 89-95' G58, W56, or R150F trans handle, or cut and weld what you have to make it fit in the factory boot.
Both trans are 25" long :greengrin:
stone4x4
conflict
Quote from: Marlin on February 10, 2004, 11:15:37 PM
So If I have an 8422r with bucketseats, which trans do I have g52 or w56?
stone4x4
conflict
stone4x4
g 52 unless the t-case is a top shift
does the t-case shift thew the trany or on top of the t-case??
conflict
It's a forward shift so I must have the g52.  but if it were a top shift it would be a w56, right?
stone4x4
foward shift is  G
top shift W
84-88
conflict
Coolness, ya'll are very helpful.  I'm in your debt!
Marlin
All 84-88 carb trucks use the G, 4 1/2" forward shifting trans.
84-85 wimpy G52, 85-88 G54, better.
W56's are only found behind the 85-95 efi motors and were made in two styles;
Top shift; 85-88 p/up, 85-89 4 runners
4" Forward shift; 89-95 p/up, 90-95 4 runners.
conflict
terrific info sir.  Thankyou for your time!
wrenchtech
I want to be like Marlin when I grow up.
Matt
1999 4runner SR5, 3.4, auto, Horizon Blue
jvministries
while we are on tranny questions what does a 88 v6 come with?
too much spent to go slow
too much spent to stay low
too much spent on the go
but it's fun you know
#16
Quote from: jvministries on March 13, 2004, 10:56:43 PM
R150F
1st: 3.830
2nd: 2.062
3rd: 1.436
4th: 1.000
5th: 0.838
rev: 4.220
Length: 25.5" / 64.7cm
Weight: 110lbs / 49.9 Kg (no bellhousing)
Input Bearing P/Ns: DG4092, 4OTM05, or 040-1
Uses a chain drive transfercase (model VF1A) that features a 2.57:1 low range (also shift-on-the-fly).
It's tailhousing has a 9-bolt pattern which is different from the R151F which is a 6-bolt pattern.
Hey Marlin, eat your heart out!  :chew: :teeth: :reg:
The Tech,
:bowdown: BigMike
brainlessfool
The Tech,
:bowdown: BigMike
Quote
:laugh: :laugh: :laugh: :slap:I've met Marlin, and your no Marlin :moon: :laugh: :laugh: :laugh:
brainlessfool
Marlin
Great answer Big Mike :dunno:
However, the question was about a R150F, but you posted a pic of a R151F with a 4.31:1 first gear.
"I've met Marlin, and your no Marlin"  thanks brainless fool
better luck next time Big Mike. :_oops:
Marlin
84runner
this is Marlin letting Big Mike have it  :slap: and this is Big Mike  :smack: got to love it
