swap options into '85 toy 4WD
Started by alfio, February 09, 2004, 11:32:20 PM
alfio
hi all
got a little project on my hands. inhereted an '85 EFI toy 4WD. i'm looking to do a full restoration (actually already under way).
anyhow, the truck came without engine and with a broken trans. i've picked up an engine/trans from an '89 (22R which won't work 'cause my truck is EFI) but i'd like to know what my options are as far as swapable motors (only toyota of course).
i can live with a slightly modded 22RE but (a) i still need to track one down, (b) i know that i'll only live with it for a little while until i'll get sick of the power/lbs. ratio
i have access to a 7MGE swap (donor cressida) but i have concerns about california smog legality (car to truck swap).
i'd like (at least) the power from the 4 cylinder T100/tacoma DOHC motor (i forget the engine code) which if i remember correctly was 150 HP with a nice torque curve+ bulletproof.
i would love to go 5VZ-FE.
welding, relocating mounts, etc. is not a problem.
what do either of these swaps entail?is retaining my trans a possibility? i know there are issues with exhaust, pan clearances, etc. do i need to swap engine+trans?
any help with this would be *greatly* appreciated. i'd like to plan this out and get it right. TIA! :thumbs:
little a
84runner
I think Chris did a little run down a while back on tranny and motor compatability in this forum about a month ago. Try a search it was some pretty good info
alfio
84runner,
any ideas on search terms? i ran a few searches before posting and apparently i missed that. thanks
little a
84runner
You know what I can't get anything either
Thumper
hey the 89 motor will work fine just bolt ur intake too it  its all the same just a diff way of getting fuel too it.
alfio
Quotehey the 89 motor will work fine just bolt ur intake too it  its all the same just a diff way of getting fuel too it
except i don't have the manifold :) wish i did, but i don't
that's why i'm thinking swap since i'm basically looking for a whole motor anyhow
little a
84runner
I believe theres a EFI manifold in the sale adds for $75.00
alfio
thanks. actually i don't have *any* of the parts for EFI (i.e. injectors, etc.) so it's either a whole motor or a swap.
little a
84runner
