Author Topic: Issue getting into gear  (Read 1461 times)
Jedi87
  • Member since Jul '06
« on: Dec 09, 2006, 05:12:59 PM »
I replaced my w56 with one of Marlins hd units, a Centerforce dual friction clutch, pilot bearing and throwout. I have noticed that it is hard to get into gear when running, it goes in but with a little work. It goes through the gears easy when it isn't running and the clutch is in. If I have it running and try to put it in gear and it's not going in, I can shut it off while still applying a little pressure on the shifter and once I turn it off it slides right into gear.
87 4runner 22re bored .030,Kieth Black pistons,stage II "272" cam ,oversized valves,New amc head,ARP studs,electric fan,Doug Thorley header,
2 1/4 flowmaster cat back,5 speed,3 inch body lift,33 inch bfg m/t's.Centerforce dual friction clutch,Marlin Crawler hd-w56,Yukon 4.88's
99 4runner SR5 v6 automatic 4x4
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
Re: Issue getting into gear
« Reply #1 on: Dec 09, 2006, 05:25:43 PM »
adjust your clutch  its not releasing completely
boggerunner
  • Turtle Points: 9
  • Male Posts: 3,140
  • Member since May '06
  • Philberbuilt
« Reply #2 on: Dec 09, 2006, 05:27:06 PM »
yep, bleed the clutch, or check if the clutch is working properly
Wermz84
  • Rock Nerd!
  • Turtle Points: 921
  • Male Posts: 3,518
  • Member since May '05
  • Ouch My Eye!
« Reply #3 on: Dec 09, 2006, 05:30:31 PM »
x3, when was the last time you bled the fluid through?  I would also just double check that the slave cylinder is functioning properly.
I like to Drive!
Jedi87 [OP]
« Reply #4 on: Dec 09, 2006, 05:36:44 PM »
I bled it a couple months ago when i replaced the master/slave cylinders. I will rebleed tomorrow and see if it helps. Everything from the motor to the axles are new, I mean everything so it shouldn't be anything big.
Stinky
  • Turtle Points: 8
  • Male Posts: 636
  • Member since Aug '05
  • my wifes vagine, it hangs like a sleeve of wizard
« Reply #5 on: Dec 27, 2006, 08:37:17 AM »
piss with the adjuster on the pedal...loosen up the jam nut, thread it out a lil n tighten the jam nut back down...
87 p/u SAS, 22RE, built, then cut up and scrapped
94 ex cab P/U, SR5, fully loaded, 3.4 swap, r150f, a/c, bumpers, 33s, glass fenders...sold
00 Stoopid Duty 250, ex cab, lariat, v-10,000
94 reg cab, 22re, duals, 38.5 boggers, sas, 4 link, tube bed, build underway... http://pirate4x4.com/forum/showthread.php?t=967836
88 Samurai, soa, buick 3.8, th350, zuki case, 1/4 done... anyone wanna buy it??
Last post Sep 19, 2006, 12:49:49 PM
by jafish
Last post Jun 14, 2007, 10:17:34 PM
by Wermz84
Last post Nov 24, 2007, 06:19:21 PM
by 79coyotefrg
Last post Dec 20, 2007, 08:23:07 AM
by 79coyotefrg
Last post Mar 13, 2008, 12:20:17 PM
by fordh8r
