Author Topic: "I Don't Have Any Heat!!!" - Tech!  (Read 6966 times)
CTENG in KS
  • Turtle Points: -501
  • Male Posts: 4,295
  • Member since Jun '04
  • ^Alfred the Great
    • CTENG's Eco-Rant
« on: Dec 03, 2006, 05:35:34 PM »
THis has been something of a battle cry around here...I suppose because of the changing weather.  Well I have had the same issue and decided to get to solving it.  Apparently this is quite a common problem.  Located on the engine side of the firewall to the drivers side is a hose connector that is a node for three hoses.  Within this connector is a ball valve that opens and closes with a cable operated by the vent/recirculate slider with the climate controls on the dash.  This valve seems to love to stick closed...you can tell it is stuck because when you move the slider is will only go so far and feels springy.  Don't keep pulling on it because you will just bend the valve arm like I did to mine.
In any case, I don't know where you would get a replacement, so I am going to see if I can bring mine back from the dead.  I used a pair of pliers to get the arm back in shape and I am letting it sit in some chem-dip carb cleaner.  I will report back my findings, untill then, enjoy some pictures!
Re: "I Don't Have Any Heat!!!" - Tech!
« Reply #1 on: Dec 03, 2006, 05:49:29 PM »
you can use a small bungy  and  hook one end  on the little plunger  and  pull the other end over to the  mastercylinder or something  to hold it firmly open,  you'll be nice and toasty
CTENG in KS [OP]
  • Male Posts: 4,295
  • ^Alfred the Great
    • CTENG's Eco-Rant
« Reply #2 on: Dec 03, 2006, 06:59:33 PM »
Good news:  These things are salvageable!
I let it sit in the dip for bout an hour and it was still stuck tight so I ran it under hot water for a couple minutes and then just started forcing it open and closed.  Did that bout 10-15 times and the rust/buildup that was keeping it stuck finally gave.  It is opening and closing pretty smoothly now.  I will prob get it nice and cleaned up and use some white lithium grease or or the like to keep it from getting stuck again.   :thumbs:
All_Set
  • Turtle Points: -145
  • Male Posts: 543
  • Member since Mar '04
    • Blue Ribbon Coalition
« Reply #3 on: Dec 04, 2006, 08:16:19 AM »
You can get that at Napa or the dealership.  I believe it was around 20 bucks.  Heater control valve.
CTENG in KS [OP]
  • Male Posts: 4,295
  • ^Alfred the Great
    • CTENG's Eco-Rant
« Reply #4 on: Dec 04, 2006, 10:11:03 AM »
I SAVED $20!!!!!
CTENG in KS [OP]
  • Male Posts: 4,295
  • ^Alfred the Great
    • CTENG's Eco-Rant
« Reply #5 on: Dec 04, 2006, 05:41:08 PM »
Lets get serious here folks...now we all know that you can't have heat unless your heat's got bling!
RRMike
  • Member since Dec '05
« Reply #6 on: Dec 22, 2006, 04:02:21 PM »
Is that hammered finish?  I like.
CTENG in KS [OP]
  • Male Posts: 4,295
  • ^Alfred the Great
    • CTENG's Eco-Rant
« Reply #7 on: Dec 22, 2006, 04:20:58 PM »
Not hammered finish...it is copper gasket spray.  For some reason it went on all swirly like that.  Once it dries I hit it with clear coat to seal it.
  • Shoutbox Moderator
  • Male Posts: 7,110
  • Member since Nov '05
« Reply #8 on: Dec 22, 2006, 04:23:49 PM »
Wermz84
  • Rock Nerd!
  • Turtle Points: 921
  • Male Posts: 3,518
  • Member since May '05
  • Ouch My Eye!
« Reply #9 on: Dec 22, 2006, 08:10:08 PM »
nice work CTENG.
I don't have any heat either.     My heater control valve is only a couple of years old so i don't suspect it, maybee I should check it anyway.  I'm thinking my heater core might be gummed up.  For all I know it's still the original one.  :dunno:
I like to Drive!
CTENG in KS [OP]
  • Male Posts: 4,295
  • ^Alfred the Great
    • CTENG's Eco-Rant
« Reply #10 on: Dec 22, 2006, 08:32:51 PM »
You will be able to tell if the valve is the problem because the adjuster in the cab for opening the valve will not slide smoothly...it will get tough to move.
RRMike
« Reply #11 on: Dec 23, 2006, 03:40:02 PM »
Well mine slides all the way smoothly but I don't get any heat.  I'm gonna screw with it this weekend hopefully and I'll post up here.
Wermz84
  • Rock Nerd!
  • Male Posts: 3,518
  • Ouch My Eye!
« Reply #12 on: Dec 24, 2006, 12:29:28 AM »
It's a little rough in a couple of spots and now that i think about it, its closer to 4 1/2 years old.  Definatly time to check.
I like to Drive!
NeverEnough188
  • Male Posts: 22
  • mine drags....
« Reply #13 on: Dec 24, 2006, 08:23:33 AM »
my adjuster inside the cab doesnt go all the way to the end of the adjustment hot side. the valve moves on the fire wall but not all the way. i assume its opening some but i still have no heat. flushing the coolant system didnt help so i am going to run some of the prestone radiator cleaning fluid (2 bottles) in the system and go on a road trip for a few hours to really work it in. we'll see....
is removing the dash necessary to replace the heater core in these trucks? i have an 81
{Travis}
81 longbed 2wd 22r. bone stock winter beater
92 s10 extended cab. bagged, shaved, getting SFBD and 4.3 build. check it out!
http://www.s10forum.com/forum/showthread.php?p=2871366#post2871366
Marlin
  • Inspirational Genius
  • Turtle Points: 138
  • Male Posts: 856
  • Member since Sep '02
  • MC³ = 1,148:1
    • Marlin Crawler
« Reply #14 on: Dec 24, 2006, 10:25:57 AM »
I dont recall removing the dash to access the heater box.
Just the glove box and brackets.
It sounds like the heater cable housing has moved where it should be secured with a pinch clip on the dash control.
CTENG in KS [OP]
  • Male Posts: 4,295
  • ^Alfred the Great
    • CTENG's Eco-Rant
« Reply #15 on: Dec 24, 2006, 07:25:33 PM »
HOLY CARP...MARLIN'S IN MY THREAD!!!!!   YAHOOOOOO!
« Reply #16 on: Dec 24, 2006, 07:40:55 PM »
:haha:   calm down  you  blow a thread gasket  :thumbs:
  • Turtle Points: 1128
  • Male Posts: 9,757
« Reply #17 on: Dec 24, 2006, 08:12:21 PM »
I've had similar problems with my cables moving on the outside rather than inside the sheething.  It's really common on first gens, or atleast it's happened to every one I've had.  I've actually had to ban passengers from touching any heater controls, but inevitably somebody plays with one and I get stuck trying to fix it.  It's how I ended up with cold air blowing in under the dash in the middle of winter :maddest:
« Reply #18 on: Dec 24, 2006, 08:37:13 PM »
mine havent worked in years  but  i can reach  under the dash  in pitch dark  and grab  the levers  they operate  and put it back where it should be in no time
Wermz84
  • Rock Nerd!
  • Male Posts: 3,518
  • Ouch My Eye!
« Reply #19 on: Dec 25, 2006, 10:11:26 AM »
:rofl:   I hate it when i blow a thread gasket!
I like to Drive!
NeverEnough188
  • Male Posts: 22
  • mine drags....
« Reply #20 on: Dec 26, 2006, 06:00:43 AM »
well i temporarily fixed the problem. th pivot point for the arm that moves the valve was rusted stuck. so i pulled out the valve assembly and soldered a couple 90* 1/2" copper fittings together to make a bypass. the fittings can be purchased at any hardware store. the only other things you need are a torch, some 50/50 solder and some flux.
{Travis}
CTENG in KS [OP]
  • Male Posts: 4,295
  • ^Alfred the Great
    • CTENG's Eco-Rant
« Reply #21 on: Dec 26, 2006, 07:22:18 AM »
Some elbow grease and white lithium grease will free up that pivot.
Last post Apr 20, 2005, 01:18:09 PM
by PinkToyota
Last post Mar 15, 2006, 12:16:23 AM
by Yota Up
Last post Jun 07, 2006, 06:00:44 PM
by kneedownnate
Last post Jul 26, 2006, 06:04:53 PM
by Broke_Okie_Ty
Last post Sep 17, 2012, 07:39:48 PM
by Duffil
