Author Topic: Rear Drum Brake Issue  (Read 4023 times)
Ranski
  • Turtle Points: -160
  • Male Posts: 73
  • Member since Nov '05
  • I have no idea what I'm doing
« on: Nov 25, 2006, 07:09:25 AM »
I'm in the process of replacing my rear drums and shoes.  I have the new shoes installed...my problem is that one of the drums won't fit over the shoes.  The other one fits perfectly over the DS shoes and is tight on the PS shoes.
Is this to be expected with non OEM parts.  Should I just go and have the drums turned so that they will fit?
I can't seem to locate a micrometer to measure the OD for the shoes and the ID on the drums.  Is this critical for me to do before they are turned?
Randy
85' 4Runner w/ lots o' Marlin stuff (and I got the stickers to prove it)
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
Re: Rear Drum Brake Issue
« Reply #1 on: Nov 25, 2006, 08:51:37 AM »
use the star wheel  at the bottom  to  adjust the shoes,  you want it  to just slip over the shoes,   DONT HAVE THEM TURNED
madhunt
  • Turtle Points: 52
  • Male Posts: 490
  • Member since Apr '06
« Reply #2 on: Nov 25, 2006, 09:07:30 AM »
the only reason you would turn the drums is if you want to get rid of the vibration it causes if the drum is wraped, otherwise do no turn them just reajust the brakes so the drumm will go on.
HIGH AND TIGHT OFFROAD
Ranski [OP]
  • Male Posts: 73
« Reply #3 on: Nov 25, 2006, 01:19:42 PM »
I star wheel is adjusted as far down as it will go.
Randy
DTB
  • Shoutbox Moderator
  • Turtle Points: 2
  • Male Posts: 7,110
« Reply #4 on: Nov 25, 2006, 01:28:22 PM »
...and did it go on??
Quote
Oddmar
  • Turtle Points: 74
  • Male Posts: 402
  • Member since Aug '04
  • J3 Productions
« Reply #5 on: Nov 25, 2006, 02:17:01 PM »
Does the star wheel turn easy, or is it a rusty lump of iron oxide like all mine? The guys are prolly right, though...the only other thing i can think of is brakes for an '84 are smaller than brakes for an '88. Did you get the right brake parts?
The hassle of working on the Toyota drum brakes is why i'm changing mine to disk brakes. That, and the fact the disk brakes will work long after the drums are full of mud and rust.
The United States Constitution © 1791. All Rights Reserved.
Only when i am finished will there be peace: The peace of an empty wind as it blows across a land strewn with the bones of my enemies.
Ranski [OP]
  • Male Posts: 73
« Reply #6 on: Nov 25, 2006, 02:45:38 PM »
It is adjusted all the way down and the drum still won't go on.  Also this is a complete rebuild on the axle so the adjuster is clean and well lubed and spins freely and I am rebuilding the brakes with all new springs...so everything should be good and tight.
According to the parts number on the box, the drums are identical.  Drum #1 fits perfectly over the PS shoes and is VERY tight on DS shoes.  Drum #2 won't fit over either side.  This is leading me to believe I have a drum that wasn't manufactured to spec.
Randy
Oddmar
  • Turtle Points: 74
  • Male Posts: 402
  • J3 Productions
« Reply #7 on: Nov 25, 2006, 02:54:31 PM »
Can you return the drums and get a different set?
madhunt
  • Turtle Points: 52
  • Male Posts: 490
« Reply #8 on: Nov 25, 2006, 02:57:11 PM »
did you callapse the wheel cylinder after you adjusted the star wheel, to make sure everything was colapsed down to the right size.  check the casting numbers on the drum itself to see if you have two of the same drums?????
Ranski [OP]
  • Male Posts: 73
« Reply #9 on: Nov 26, 2006, 06:45:20 PM »
Quote
Checked the casting number and they do match up.  This is sooo frustrating...I have been working on the build for a year now and I'm near the end.  I certainly didn't anticipate the brakes giving me troubles. :smack:
Randy
BUBBA
  • Turtle Points: 16
  • Male Posts: 1,138
  • Member since Mar '05
  • this sucks
« Reply #10 on: Nov 27, 2006, 06:26:58 AM »
I would take the drums back and exchange them
My budget beater
Stinky
  • Turtle Points: 8
  • Male Posts: 636
  • Member since Aug '05
  • my wifes vagine, it hangs like a sleeve of wizard
« Reply #11 on: Dec 27, 2006, 01:01:06 PM »
wat happens with that drum setup is the shoes sit inside the edge of the drum, n they wear it down leave a lip, which is a pain in the ASS to get the drum off...and when putting them back on w/ that lip, it takes forever to adjust the shoes after they get opened up to clear the lip....so take it to aprts store of if u know someone w/ a brake lathe, n have them cut the first 1/4" of the drum down....that way when it wears down, theres no lip and it comes off wayyy easier.....
87 p/u SAS, 22RE, built, then cut up and scrapped
94 ex cab P/U, SR5, fully loaded, 3.4 swap, r150f, a/c, bumpers, 33s, glass fenders...sold
00 Stoopid Duty 250, ex cab, lariat, v-10,000
94 reg cab, 22re, duals, 38.5 boggers, sas, 4 link, tube bed, build underway... http://pirate4x4.com/forum/showthread.php?t=967836
88 Samurai, soa, buick 3.8, th350, zuki case, 1/4 done... anyone wanna buy it??
Last post Aug 10, 2007, 09:10:53 PM
by Craftsman
Last post Dec 21, 2007, 10:04:54 AM
by 79coyotefrg
Last post Apr 27, 2009, 09:36:28 AM
by sggirbyt
Last post Dec 09, 2013, 04:02:54 PM
by Rockdwg
Last post Nov 02, 2012, 05:59:17 PM
by desrodunes1
