Author Topic: tranny swap  (Read 1210 times)
RABIDYOTA
  • Turtle Points: -107
  • Male Posts: 336
  • Member since Mar '06
tranny swap
« on: Nov 17, 2006, 06:20:54 PM »
? what will i have to change to mount a 86 5sd in to a 83,  my main ? is will i have to move the tranny mount. its dark and wet out and i don't care to go lie under it tonight and mesure every thing. thanks
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
Re: tranny swap
« Reply #1 on: Nov 17, 2006, 06:31:28 PM »
86 tranny in a 83  :yikes:  you have to shorten the rear driveshaft about 6 inches,  lengthen the front,  move the crossmember,  cut a new hole in the floor.  basically  everything you would have to do if you were going dual cases
get a L52HD from Marlin  they will bolt right in to your 83  and its as strong or stronger than the 86 G54 tranny
RABIDYOTA [OP]
  • Male Posts: 336
Re: tranny swap
« Reply #2 on: Nov 17, 2006, 06:37:48 PM »
not my truck doing a engine swap found front trans bearing toast, i have a spare trans and t case  i was going to offer him.  ( o and i would get to keep his top shif t-case)
All_Set
  • Turtle Points: -145
  • Male Posts: 543
  • Member since Mar '04
    • Blue Ribbon Coalition
Re: tranny swap
« Reply #3 on: Nov 20, 2006, 01:17:56 PM »
The speedo cable may be a tad too short too.  Which reminds me.  I need to purchase the extension from this site.
Last post Jan 26, 2010, 05:44:23 AM
by ringer
Last post Aug 27, 2010, 09:02:18 PM
by 4x4yota
Last post Dec 28, 2012, 05:01:48 PM
by 3toys
Last post Jul 24, 2013, 02:55:35 PM
by moutaintoys
Last post Aug 22, 2013, 04:38:29 AM
by R.DesJardin
