Need picture's
Started by rockcrawlinredneck, November 16, 2006, 07:07:34 PM
rockcrawlinredneck
Of how Marlin's tube bumper's mount. I am sure there is some way that it ties into the body mount but I cant find a good pic of the way that it mount's. Can someone post a pic of the mount's please.
Kevin
to the frame  i would think,  not the body mount  :eek:
rockcrawlinredneck
I am sure it mount's to the frame also. But how does it mount on the upper half of the bumper. Like where the winch plate sit's, this is why I want to see PICTURE'S. If you can see it then there is no confusion, and people scracthing their head.
Kevin
rockcrawlinredneck
rockcrawlinredneck
Hey rocktoy, can you also take a picture from the driver seat looking out the front? I am curios to see how much of that stinger you can see and if it creates a blind spot.
kevin
DTB
There are 2 different size stingers made on this product, large and medium. The medium has little to no visibility problems, not sure about the large one.
DTB
I believe that there  are 6 tie in points, 2 bolt on the frame, 2 weld plates and 2 into the body mounts. I'll see if I can get a pic for you too.
rocktoy83
Got you sum pics  :thumbs:
rockcrawlinredneck
Thank's rocktoy. I have a couple of Q's for you still. The mount that goes to the body mount, is that a pice of angle with a hole drilled in it. It is kind of hard to tell how it actually attaches. Also the mount on the bottom outside bolt's to the stock bolt hole right, but it look's as if the other half of that bracket is welded on to the frame. Is this correct? If so why is the other two support's made with flanges for removal? Or is this somthing you did on your own and not a part of the original design? Thank's again for the pic's. :beerchug:
Kevin
