Author Topic: need some help with diagnosis  (Read 1794 times)
flipskid
  • Member since Nov '05
« on: Nov 14, 2006, 07:21:48 AM »
was out on the trails on Sunday.  I have dual cases and had the front case in low with the rear case still in high, still in 2 wheel drive.  all of a sudden I hear a clanking gear type nois from the area of the transfer cases. put in the cluth and put it in nuetral then try to move the gear shifter in the front case-no go.  try the second case-no go.  both locked up.  put the trqnny in reverse and it breaks the transfer cases frede and it drives fine until a little while later it does the same thing.  do the smae fix drive it some more.  now in 4 wheel first low and it does it again-same fix.  when it locks up the truck will not go anywhere until I put it in reverse to free up the binding.  all the drive shaft bolts are tight, ring and pinions are fine.  tranny is very new.  the dual cases is a used unit.  I know i have to rip it out, just wondering if this sounds familiar to anyone.  I am thinking the dual adapter is an older Marlin unit.  thanks, JR
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
Re: need some help with diagnosis
« Reply #1 on: Nov 14, 2006, 07:48:50 AM »
sounds like  a  ball bearing  got loose and is  getting picked up  ands tuck in the gear,  gotta  pull the cases  for sure  and find out whats in there  thats getting between the gears  befor something REALLY BAD happens  in there
Hottrod81
  • Turtle Points: -2
  • Male Posts: 1,392
  • Member since Feb '05
  • Full Trucker Effect
« Reply #2 on: Nov 14, 2006, 08:33:16 AM »
I agree with Glen.
4inchToyotas
  • Turtle Points: -260
  • Male Posts: 351
  • Member since Sep '05
  • Wheeling does exist in the ATL
    • Georgia Cruisers
« Reply #3 on: Nov 14, 2006, 08:35:05 AM »
send it to me and I'll do it...oh I just won't send it back  :eyebrow:
2006 Tundra DC 4x4 - DD/Tow (if I can ever find a place to store a trailer)
1983 Hilux - 20/22r Weber 32/36 carb, 4" ProComp suspension, 5.29's Lockrite Front, Spool rear, 34x10.50x15 LTBs
flipskid [OP]
« Reply #4 on: Nov 14, 2006, 12:05:57 PM »
thanks for the quick posts, JR
All_Set
  • Turtle Points: -145
  • Male Posts: 543
  • Member since Mar '04
    • Blue Ribbon Coalition
« Reply #5 on: Nov 14, 2006, 03:04:45 PM »
Take pictures and report back!
K
Tks
Gbye.
:D
Putting in duals this week and would be good to know what blew up in yours.
flipskid [OP]
« Reply #6 on: Nov 14, 2006, 05:24:23 PM »
it sure would be nice to know.  Will have to see about rebuild options, what marlin sells and what i can do myself if that is an option.  it always had a lot of noise to it, but not the bad kind. you have all your drive line pieces in order?  that was one of the hardest parts, locating all the right year joints.
Last post Dec 03, 2004, 02:57:59 PM
by Mike D
Last post Sep 10, 2006, 09:52:56 PM
by Duffil
Last post Jun 14, 2008, 09:53:24 AM
by Dr.Maxwe001
Last post Nov 10, 2012, 06:47:58 PM
by finisher424
Last post Dec 31, 2016, 05:43:39 AM
by jbramble24
