So what you are saying is that you want to remove your draglink from your pitman arm? If so there will be a cotter pin running across the end of it, pull that pin then use a big screwdriver and back the nut off. That will slack the fitting and you should be able to pull it off.
Kevin
*EDIT* man I type slow 79Coyotefrg beat me to it.
