new member
Started by Hyena, February 02, 2004, 09:22:36 PM
Hyena
Yep, and i got board, so i went to a friends house and cut them off lol.  im thinking of doing whats in the picture.  try and make it a little stronger, crappy picture though.
WHITE_TRASH
Thats probobly a good idea.  If done right they wont look too bad either.
WT
Hyena
I got the passenger side nerf bar/rock slider welded on today.  Will get the drivers side welded on on thursday and then i can paint them and take pictures on the weekend.
84runner
Did you weld the tubing straight to the frame?  Or did you use a piece of flat plate?
Hyena
straight to the frame.  I know it might bend the frame.  But i have a couple supprot bracket things that will be welded on.  Hopefully the 4 supports and the brackets will keep the frame from bending.   :dunno:
84runner
make a gusset for each side of the tubing to the frame and you should be ok
Hyena
got some pictures of the one thats on there.
Hyena
the ends
Hyena
the four supports welded to the frame, still not done though.
84runner
Those look sweet and you got them tucked in close. NICE :thumbs:
Hyena
thanck you, and they only cost me $72 for 20 feet of 2x2 .120 wall!   :biggthumpup:
Red_Runner
hay those things look great all sucked up makes mine look sloppy
Hyena
I got the other one on today, a couple more welds and they will be done.  Finally!  Now, my fuel pump is clauged, gotta get the replaced this weekend.
Hyena
replaced my fuel fliter, hopefully that helps the problem of starting up slow.  I also cut out my front finders, it looks sweet.
Hyena
I found a picture of my truck when i first got it, gone through a lot of changes.
Red_Runner
that was one nice toy now its no its way to be one bad toy
Hyena
I found some chevy springs on Pirate for $125.  I might just get them if he can meet me.  He lives in Petiluma i think.  They would help a lot with the flex.
Red_Runner
yah my buddy has them on his 84 long bed they flex pretty good
Hyena
here are my half doors, i made them with a friend.
Hyena
another
Hyena
last pic
Red_Runner
hay they look pretty good I have some spar door how hard will it be for me to make some?
Hyena
Its really not that hard.  You jst have to lay out what you want it to look like.  Cut it out with a sawsall or a plasma cutter (use a friend for the sawsall as it will vibrate uncontrallibly)  Then you need to fabircate something to open the door.  I just cut the origonal door opener rod and bent it into a circle.  I can pull it to open it.  I then put 2x4 wood on the gap, put carpet padding on it, then used a leather type material.  It didn't take too long.  I also helped built some for a friend last week.
Hyena
I picked up a dual transfercase and i put on my chevy springs.  All i have to do is install my dual cases and it will be awsome, i hope.
Red_Runner
man you are moving pretty fast with that rig Im still saving to rebild the motor but im thinking of selling my rig right now need the $$$$$$$
Hyena
I saved up my money, and plus im only 17 and i live at home, don't have to pay rent.  But right now i have ideas for a front dif guard and i still have to reinforce my front bumper, and install the cases.  and now i need new rear shocks, my 5012 i have on there aren't long enough.  i will get some pics of my flex with the chevies tomarrow, without rear shocks.
Hyena
here are the crappy pics with the chevies.  I was getting mad because the double shackles werent even extending all the way.  The shocks were off because i didn't know if they were long enough.
Hyena
Hyena
84runner
Lookin goood from here  :thumbs: A good idea for diff armor I think is a 8 inch pipe cap and cut it in half then clear it for the filler plug and make a drain hole then weld it on :biggthumpup:
