Author Topic: how do i hook up an aftermarket tachometer.  (Read 1817 times)
yotadork83
  • Turtle Points: 18
  • Male Posts: 705
  • Member since Mar '06
  • ninja turtules rule!!
« on: Nov 11, 2006, 02:22:26 PM »
i am trying to hook up a tach to this type of coil and i dont know which wire to tire into. to make it work.
yotas 4 life homie!
KYOTA
  • Turtle Points: 1759
  • Member since Jan '04
  • Wreckin Ball '09
Re: how do i hook up an aftermarket tachometer.
« Reply #1 on: Nov 11, 2006, 03:41:37 PM »
either 2 on the right in your pic.  I used the one in the middle but the one on the right works too
crawlerdan
  • Turtle Points: 1319
  • Male Posts: 4,770
« Reply #2 on: Nov 11, 2006, 03:44:08 PM »
there is a plug on the side closest to the firewall that is the tach lead, if you dont have a factory tach, use this, if you dom tap into that same plug
other than that-black goes to ground, and white goes to switched power with the red wire as well
Last post Oct 05, 2006, 12:09:15 AM
by SoCal80
Last post Nov 26, 2010, 02:11:18 AM
by locked 4x4
Last post Aug 10, 2012, 07:24:31 AM
by Larryb
Last post Jun 30, 2014, 03:20:25 AM
by Speed
Last post Oct 23, 2015, 09:06:25 AM
by redneckcustoms13
