Author Topic: v6 taco 3rd member  (Read 2034 times)
JCTACO
  • Member since Nov '06
v6 taco 3rd member
« on: Nov 06, 2006, 04:30:27 PM »
is the v6 taco 3rd member the same as v6 4runner,not sure what year but is a coil sprung housing.
  • Turtle Points: 2872
  • Male Posts: 8,707
Re: v6 taco 3rd member
« Reply #1 on: Nov 06, 2006, 04:45:25 PM »
are both trd elocker equipped or neither? or one is and one isnt?
« Reply #2 on: Nov 06, 2006, 06:32:27 PM »
chances  are very good  the answer is yes
its easy to put a elocker into a non elocker housing
easy was is to look at the axle code on the door jam
  • Male Posts: 8,707
« Reply #3 on: Nov 06, 2006, 06:42:03 PM »
if the taco is not a elocker equipped truck, than the answer is no, as in it isnt the same at all...
i think the 4runners used the v6 8"
« Reply #4 on: Nov 06, 2006, 08:40:22 PM »
if its the 8 inch  which can be confirmed by the axle code on the DOOR,   then YES  a elocker can be installed ,with some "modification"  of the housing
theres a 8.4 inch axle  in some tacoma's,  and its also in "some"  late model  runners      if  you are unlucky  enough to get one of these,  your just  screwed  they came mostly in NON TRD tacomas  and T100's
my neighbor has a 98 taco with A340F  and a 8 inch with 4.56  gears  from the factory
just check the codes on the door
gabriul
  • Male Posts: 100
  • Member since Apr '06
« Reply #5 on: Nov 19, 2006, 08:12:36 PM »
I wouldnt' call cutting part of the housing, fabbing in two corners, retapping three holes, and hoping everything lines up with the third "easy"
But, it can be done.
If they are non e-locker 3rds, it will match up allot easier.
Last post Dec 10, 2003, 07:25:11 PM
by 95TacoTruck
Taco SAS
Last post Nov 29, 2004, 11:19:50 AM
by BigMike
Taco SAS
Last post Feb 25, 2005, 01:56:21 PM
by stomper
Last post Oct 25, 2005, 09:32:29 PM
by johnw
Last post Nov 26, 2005, 02:07:28 PM
by Crawler677
