Author Topic: New Bushing = New Bolt?  (Read 2738 times)
Bender
  • Turtle Points: 44
  • Member since Jul '05
« on: Oct 30, 2006, 04:04:08 PM »
When I swap out the bushings on my springs/shackles, should I change the bolts at the same time?  I have the greasable bolts and they're a bit expensive, but if that's what it takes to do the job right I'll go for it.
Thanks!
  • Shoutbox Moderator
  • Male Posts: 7,110
  • Member since Nov '05
Re: New Bushing = New Bolt?
« Reply #1 on: Oct 30, 2006, 04:07:46 PM »
I usually use the same ones. If they can be removed that is. I usually have to cut them out :flamer:
Bender [OP]
  • Turtle Points: 44
« Reply #2 on: Oct 31, 2006, 02:48:14 PM »
Thanks, I'll make sure and have some spares around just in case.
Along the same lines, is there a torque spec for the bolts or do you just make sure they're good and tight?
AaronB
  • Turtle Points: 287
  • Male Posts: 2,452
  • Wish I Was Crawling
« Reply #3 on: Oct 31, 2006, 05:20:03 PM »
Hey Bender, where did you get your bushings at? I need to get some.
  • Turtle Points: 1128
  • Male Posts: 9,757
« Reply #4 on: Oct 31, 2006, 07:10:22 PM »
At the top of this section, general 4wd, there's a thread for factory toyota parts discount.  I bought the factory bushings for a reasonable price.  Can't remember how much, but less than you'd expect!
Bender [OP]
  • Turtle Points: 44
« Reply #5 on: Oct 31, 2006, 08:32:03 PM »
I got mine from inchworm through AllPro.  I have their front springs.  They were $1.50 each.  The bolts are $12 each!!!   :shocking:  http://www.allprooffroad.com/index.php?option=content&task=view&id=48
  • Male Posts: 7,110
« Reply #6 on: Nov 02, 2006, 03:31:21 PM »
There is a spec. I think it's like 63 lbs or something. Make sure the bolt/nut are snug on the bushing. If not it can cause pre-mature bushing wear/failure. U want them tight enough but not too tight to cause any binding if that makes sense
AaronB
  • Male Posts: 2,452
« Reply #7 on: Nov 02, 2006, 04:06:49 PM »
Thanks
  • Male Posts: 7,110
« Reply #8 on: Nov 02, 2006, 04:19:56 PM »
Thanks
i got mine at a local supply store. 5 bucks a piece.
Bender [OP]
  • Turtle Points: 44
« Reply #9 on: Nov 04, 2006, 06:24:00 PM »
It's a good thing I decided to have some bolts on hand.  Two of them were in pretty bad shape.  I used new bolts all the way around and kept some of the old ones as spares.
2low4high
  • Member since Mar '07
« Reply #10 on: Mar 15, 2007, 04:50:48 PM »
good thinking. your quite sharp!
Last post Aug 17, 2005, 08:02:50 AM
by CTENG in KS
Last post Jul 20, 2005, 08:33:39 PM
by 1Bad4Runner
Last post Jan 21, 2007, 06:54:06 PM
by toybuilt
Last post Apr 03, 2009, 04:19:18 PM
by REG535
Last post Mar 18, 2012, 02:56:52 PM
by Peterbuilt84
