just born crawler
Started by crawlin2u, January 28, 2004, 10:36:45 PM
crawlin2u
 Currently have a 85 toyota pickup, front:  85 housing,d44 kit with high pinion with an arb lockerand 5.29 gears,rear springs cut and lengthened and put in the front, hy-steer set up from all pro. Rear: 86  housing with stock axels, a detroit lockerand 5.29 gears, running allpros 4 inch longer springs. 4to1 in the stock '92 t-case mated to a '92 tranny with a centerforce 3 clutch. T-case brake a warn 8000i winch and a custom flat bed bobbed. the rest is typical trail goodies
I creep and I crawl, thats what I learned first
84runner
Red_Runner
crawlin2u
I have  some  here , i need to dig them up be patience  ill post them soon
84runner
#4
patience :talkingn:
crawlin2u
im in the middle of rebuilding my front and rear  end , the rear  ouch, i was wheelin around baker lake  here in wa.  and i decided to do a burn out on pavement, well i did it and BOOM i heard , what was that ?, well turns out the bold that holds the ring to my detriot came uncrewed and got shot out the rear housing blowing a hole about  1/2 in    drove it home welded the hole  for temp and now im taking the whole thing apart  front and rear   i thought well  it was time to do a rebuild on my knuckles too, so might as well
Red_Runner
ouch good luck I just blew the motor in my 85 runner so i have to save up some mony to rebild it. Have fun i know i will
84runner
Crawlin2u  you got a pic of that little piece of  carnige
