hey marlin , solve this
Started by crawlin2u, January 28, 2004, 10:18:39 PM
crawlin2u
Hello there, I have  a few questions here reguarding the front d44 kit. Back in  i think 2001 there was a shop located in everett washington that was  called  redline off road. The shop was ran by kieth, he was building the d44 axel kit for around 600 dollars, well i have one running on my toy right now  works  Great and  really good havent broke a u joint yet. but back to the reason im e mailin ya  does the new  d44 kit that randys r and p make ( i believe is a copy of keiths design).  I want to know  if the actural axels shafts were to break past the u joint would  randys kit fit in place.I  dont know if you guys were  informed about this shop back  a yrs ago. but he is currently not in biz any more. you guys work with randys  quite i bit and you might know  , thanks a bunch.  Or anyone know what I am talkin about here ?
I creep and I crawl, thats what I learned first
yotacrawler85
85 cab on a 87 sas frame with 6 inch lift, 15x10 wheels, 34-10.50 swampers, all pro high steer, shock hoops, dual diff guards, in cab roll cage, rancho 5000s, all poly bushings remote diff breathers front and rear recievers, welded rear(4:30's) 22re
crawlin2u
this sucks ,no  one has any idea if the birfield eliminator kit  by randys will fit , no one ?
Prismo
The only thing I could find was pictures of each kit. This is the Redline kit
Prismo
I suck at the internet. Try again
Prismo
This is the randys kit. I know Keith was machining the back of the hub to fit the axle, don't know if randy's is doing the same
Marketing
It would take trying it to see if it fits. We don't have a readline kit to work with here.
crawlin2u
Wow ,ok thats great, I currently have the kit now  from redline  and i was just really interested in  randys set up,  so i dont have to go back to birfields , they suck, I also believe that kieth was  machiining the inside of the spindel too, I was  told from one of the guys  at randys (jc or jt)that  they used kieths ideas and  that the kit wa going to be very similar, I guess what i really need to do is ask randys ring and pinion Thanks a bunch, shayne
crawlin2u
Hey,  prism, where did you locate that picture, thats the kit, is it yours ?
Marlin
#9
Randys kit includes a new custom spindle. I would like to beleive that Randys axle would slide right in. You are correct, Randys kit is a direct copy of Keiths design. Keith told me this in person :hammer:
Keiths axles were made by Mosser.
I beleive that Randys axles are made in India?
The only sure way would be to remove your axles, and measure them, then call Randys and check to see if they really are the same.
Marlin
Prismo
I googled the picture. I did a search for Birfield Eliminator. I do have one in my front axle right now (the Redline kit).
Prismo
Sorry I didn't read Marlins post, Randys axles are made in India.
Here is the link to the Redline picture & text http://www.4x4wire.com/toyota/reviews/birfield_elim/
Marlin
So you are running only one redline axle (rh side)?
Marlin
Prismo
Both sides, a whole kit, sorry for the confusion. It is one of his earlier kits. Just put it back in after taking the 60 hybrid out.
Marlin
Now I know who you are :hammer:
It comes to reason that we have both learned a big $$$$ lesson.
I sure love my fine business cards  :ladys-man:
Your best bet is to check with Randys (you already knew that)
It would be great if they were the same :crossed:
Marlin
Prismo
Such is life, tis only money. Glad you like the cards.
Marlin
Quote from: prism on January 31, 2004, 12:29:14 AM
Still waiting on the bill for the last ones?
Thanks again-- Marlin
Prismo
Toyoballs
Quote from: prism on January 31, 2004, 12:04:02 AM
Hey Prism, Why did you remove the hybrid 60? and have you heard any feedback on how Randy's setup is taking punishment compared to say like "Bobby Long's" stuff?
Just Grind It Down To Metric...
"MAKE IT OR BREAK IT"
Extreme Off-Road Club
Prismo
My truck is and always will be a compromise. I wanted a truck I can drive to and from where ever I wheel & be able to do a few long trips each year (my daughter lives in Vegas). I also wanted something I could sleep in. The 60 hybrid would work well if it was a trailer queen & I was running hydro steering. The highway manners of the hybrid were not what I was used to ( I know I am a whimp). Without a good amount of work & $$$ it will not work for my purposes. We may try it later in a trail only rig.
The birfield eliminator kit is plenty strong, but strengthened birfs are cheaper. If you trash an birf axle you can always find a replacement (even if it is an untreated birf) near by. By the time you pony up the money for a set of replacement birf eliminator axles to have spares plus the eliminator kit, you are into enough bucks to buy a lot of treated birfs! Even if you found and axle locally for the birf eliminator you would still have to get it machined & splined to use it. I will probably be going to strengthened birfs by summer for just this reason. My :twocents:
crawlin2u
right on, this is what i expected, i knew that kieth told me  what he was exactly doing and  i do believe  that randys axels will fit , however i have not broke an axel yet not even a u joint, yea its a good kit ill say, and i do belive the stock birfields can still be used in the housing if i  ever do break an 44 axel ,ill slip longfields in. Thanks marlin i know  i need to call randys for sure but i thought you might know some info too  never hurts to ask, ask , ask and ask questions  alos i need a knuckle rebuild kit  im doin my front end  again
Marlin
Quote from: crawlin2u on January 31, 2004, 04:42:11 PM
We have hub kits in stock!
       Give us a call
Marlin
Prismo
I just talked to Keith and according to him both the Redline & the Yukon axles are the same & will interchange
Marlin
#23
Great to know :biggthumpup:
I alway knew that Randys ripped of Keiths idea by simply copying it!
Marlin
crawlin2u
prism you know kieth and talk to him  a bit, whats he doin now these days  back to work at shinn mechanicle ?  how did his rear disc brake set up turn out like did he ever finish it  , he had good ideas , good work too
crawlin2u
if i order a kuckle kit , gaskets and all ,when would i recieve it if i ordered it on monday from ya ?
Marlin
Quote from: crawlin2u on January 31, 2004, 09:39:04 PM
Two days ground UPS to Everett WA. Sent monday, you would have it wed.
Marlin
crawlin2u
right on  ill do that, need it  , thanks  what  do you know about cams ,  i have  a cam from nw off road for a turbo efi motor but its the same as a  cam for a normal efi motor, the efi cam  valve lift is .426I and .440E  turbo cam is.431I and .443E  the duration is the same though 250/260 do ya know if its worth doing, my motor is a 85 stock .  thanks   shayne
Prismo
Quote from: crawlin2u on January 31, 2004, 09:36:06 PM
I believe he is doing HVAC work again. I don't know if he finished the brake kit or not. I know he doesn't have his 4-Runner any more, he may have completed the set up on that one before it was sold.
crawlin2u
yea i remember that runner coils  and all    cool  yea i know he was doin that work cause thats what i do too , hvac/r
