Author Topic: I HATE CARBS!!!!!  (Read 6122 times)
rednk1980
  • Male Posts: 1,295
  • Member since Mar '06
  • Pull Your Panties to the side!
Re: I HATE CARBS!!!!!
« Reply #30 on: Oct 11, 2006, 09:44:18 PM »
:dunno:
rednk1980 [OP]
  • Male Posts: 1,295
« Reply #31 on: Oct 11, 2006, 10:42:56 PM »
Monday its headed to the Engine shop.  :down: Hopefully they'll be able to fix it either that or im puttin in efi!
  • Administrator
  • Turtle Points: 2159
  • Male Posts: 18,292
  • Member since Apr '02
  • 511:1 Club
« Reply #32 on: Oct 12, 2006, 09:32:49 AM »
Would this be the same thing as the fuel cut solenoid?
:yesnod:
rednk1980 [OP]
  • Male Posts: 1,295
« Reply #33 on: Oct 12, 2006, 03:40:29 PM »
So i decided to give it one last try before the truck goes out monday to the shop. I checked the grounds and cleaned all of them. I'm puttin the weber back on(stock carbs are way to confusing  :hammer: ) the truck runs now but wont go above 2000 rpm without backfireing and if it goes below 2000 rpms it just cuts out and dies. any suggestions or info on why this might be happening  :dunno:  (stock carb was just rebuilt totally)
854RUN
  • Turtle Points: 30
  • Male Posts: 890
  • 4WHEEL 4EVER
« Reply #34 on: Oct 13, 2006, 06:58:39 AM »
Igniter, coil, or timing maybe  :headscratch:
-JOSH-
derek
  • Turtle Points: -61
  • Male Posts: 600
  • slow truck=more time to nap
« Reply #35 on: Oct 13, 2006, 07:35:40 AM »
YUP, sounds like ignitor or coil problem.
bluetoy84
  • Turtle Points: -100
  • Male Posts: 300
  • Member since Jun '04
  • rice bouncer
« Reply #36 on: Oct 13, 2006, 11:19:22 AM »
I know this sounds stupid, but are you sure your plug wires are in the right firing order? An old mechanic showed me one time that if you have trash in you carb you can swap two plug wires and crank the motor, and it will backfire through the carb and clear out the trash. I have had to do this several times and with the wires crossed it runs exactly how you describe yours. Maybe someone swapped your wires as a joke? We used to do this to people back in high school.
Anyways, If it won't run right with a fairly new weber, I don't think your problem is the carb. Definately sounds like an ignition or timimg problem to me. Most of the coil/igintor problems I've seen the truck would not run at all. Backfiring is a sure sign of a timing issue. I would check all things timing related.
Willy Mammoth
  • Male Posts: 4,252
  • Member since Nov '04
« Reply #37 on: Oct 13, 2006, 04:13:27 PM »
Maybe even check the cam timing? I have seen chains jump a tooth and run like crap too.
Check cam timing, firing order, plugs for black soot or wet fuel fouled and maybe even your distributor to see if ther is any loose play in the shaft that could cause a missfire at high rpm.
rednk1980 [OP]
  • Male Posts: 1,295
« Reply #38 on: Oct 13, 2006, 11:21:08 PM »
thanks guys im pretty sure now that i've thought about it that the chain jumped a tooth when i changed the head gasket. so how do i fix that problem?
Last post Nov 19, 2004, 06:47:33 AM
by 83yota
Last post Jan 27, 2005, 11:05:40 PM
by Runninthetrails
Last post Jan 03, 2007, 09:43:02 PM
by te51levin
Last post Nov 03, 2010, 02:57:51 PM
by skin6061
Last post Feb 23, 2012, 01:55:41 PM
by BigH559
