Author Topic: So...ummm...yeah, this sucks  (Read 4584 times)
Tice
  • Turtle Points: 8
  • Male Posts: 881
  • Member since Feb '05
  • I named my son Wheeler!!!!
« on: Sep 27, 2006, 06:34:06 PM »
Found this in my rear case and there is a little in my front. I'm thinking just let it drain for a few days and fill it back up with oil. I think it happened when I was swapping everything over the past several weeks. If so then I've only got about 40 miles of use with the water in the oil. Any one reccomend something for getting most if not all of the contaminated oil out? I think I may have to remove my front case since there is no drain. Maybe I can remove one of the lower mounting bolts. :dunno:
I don't need a winch, I wheel a TOYOTA!!!!!!!
www.wheelingarizona.com
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
Re: So...ummm...yeah, this sucks
« Reply #1 on: Sep 27, 2006, 06:36:23 PM »
:yikes:
yea  my mc07  has a drain :dunno:
CTENG in KS
  • Turtle Points: -501
  • Male Posts: 4,295
  • Member since Jun '04
  • ^Alfred the Great
    • CTENG's Eco-Rant
« Reply #2 on: Sep 27, 2006, 07:29:09 PM »
I would def. drain it, put in new oil and take it for a ride to cycle the new stuff through, then drain it again.
Tice [OP]
  • Turtle Points: 8
  • Male Posts: 881
« Reply #3 on: Sep 27, 2006, 08:39:36 PM »
:yikes:
Guess I better look harder then.  :gap:
Thats what I was thinking. I just don't want my rear case to go out, cuz it has my 4.7's. I got a spare case for the front though.
Duffil
  • *lurker*
  • Turtle Points: 138
  • Male Posts: 4,844
  • Member since Nov '04
    • PhotoBucket
« Reply #4 on: Sep 27, 2006, 10:06:59 PM »
I dunno how good it would be for the cases, but with bikes, we take and put in some lacquer thinner and about a half quart of oil, run it for about 30 sec or so, drain, and refill with fresh oil.  It doesn't hurt the wet clutch or the trans gears, but I don't know about how the Toy case would react to it.  You might try WD 40 (it's hygroscopic).
toyman1994
  • Turtle Points: -32
  • Male Posts: 59
  • Member since Jul '05
  • I reject your reality and substitute my own...
    • Wheeling Arizona
« Reply #5 on: Sep 28, 2006, 05:59:04 AM »
Tice, there is a drain on the bottom of your front case, I seen it there myself...fill up the cases, both of them, run them around the block a couple times and drain again.  That's my suggestion.
RynsToy
SAS'd and Caged 94 PU on it's 4th set of tires in 6 months and hasn't moved an inch, currently, stock '65 GMC wheels.
RIP: Corporal Victor M. Langarica - 20 Jan 2007
Hottrod81
  • Turtle Points: -2
  • Male Posts: 1,392
  • Full Trucker Effect
« Reply #6 on: Sep 28, 2006, 10:03:37 AM »
I would spraying the inside with a ton of brake clean.
olivedrab85
  • Turtle Points: 102
  • Male Posts: 548
  • "Ghost ride the whip"
« Reply #7 on: Sep 28, 2006, 10:19:08 AM »
x 2 I didn't clearance my shift collar enough when I installed my 4.7 set amd had to grind it in the case, so I got alot of metal in there. I just sprayed like 2 cans of brake clean in it and changed the oil twice, no problems.
"Gotta keep it G rated for Marlin"   my runner http://board.marlincrawler.com/index.php?topic=26527.0
Tice [OP]
  • Turtle Points: 8
  • Male Posts: 881
« Reply #8 on: Sep 28, 2006, 02:09:23 PM »
Well aren't you observent!!!!!!!!! :moon: I think I might drop some diesel in there to flush it and then fill it up and leave it.
toyman1994
  • Male Posts: 59
    • Wheeling Arizona
« Reply #9 on: Sep 29, 2006, 06:16:35 AM »
what the diesel or the water?? :gap:
RynsToy
hugh jeffner
  • Turtle Points: 152
« Reply #10 on: Sep 29, 2006, 06:01:19 PM »
fight nice now you two......
Tice [OP]
  • Turtle Points: 8
  • Male Posts: 881
« Reply #11 on: Sep 29, 2006, 07:34:56 PM »
Oil smart ass!!!!!!!!!!!!! :gap: I ended up  spraying an ass load of WD-40 in it and had Wheeler tunr the back tires to get the gears mving, I knew that kid would come in handy one day!!!!!!!!! :gap:
toyman1994
  • Male Posts: 59
    • Wheeling Arizona
« Reply #12 on: Sep 29, 2006, 09:20:42 PM »
Wheeler turned the wheel huh.... :smack:
RynsToy
toyman1994
  • Male Posts: 59
    • Wheeling Arizona
« Reply #13 on: Sep 29, 2006, 09:22:11 PM »
How can you fight nice??  Riddle me that Batman?? :moon:
RynsToy
Willy Mammoth
  • Male Posts: 4,252
« Reply #14 on: Sep 30, 2006, 05:04:26 AM »
This happens all the time here in the swamp lands. Best thing to do after going off the deep end is to let it sit overnight and crack the drain plugs on all the gear boxes and diff's to see if water is the first to come out.
If you catch it soon enough you can drain the water out without having to change the oil, BUT if the oil has turned milky it is too late.
Just drain, fill, drive and repeat. Also check to make sure your seals aren't leaking cause seals that leak oil will also leak water.
If you know you are going to be swamping a lot extend your breathers for your diff's and gearboxes to just under your hood by the firewall or your snorkel if you have one.
Avoid using thinners, brake clean, gas, diesel or any other type of solvent inside the cases. This will cause the seals to swell and shrink making them leak. also when they get hard from this they will wear grooves in your flanges making more leaks.
BTW, If you are using synthetic gear oil and play in water STOP. Synthetic oil is hydroscopic (like a sponge) and the water will mix with the gear oil making it useless. At least good ole 85-90 will have some lubricating properties when wet.
hugh jeffner
« Reply #15 on: Sep 30, 2006, 09:18:52 AM »
i guess your right.......but why do i have to be batman?
toyman1994
  • Male Posts: 59
    • Wheeling Arizona
« Reply #16 on: Oct 01, 2006, 02:32:45 AM »
Oh so you're saying that you would rather be Robin??
RynsToy
hugh jeffner
« Reply #17 on: Oct 01, 2006, 05:46:50 PM »
is this all you have to do over there, pick on us poor civi's?     :gap:
toyman1994
  • Male Posts: 59
    • Wheeling Arizona
« Reply #18 on: Oct 01, 2006, 10:28:44 PM »
as of this moment...yes...so feel the privilege :therethere:
 :wave:
RynsToy
rednk1980
  • Male Posts: 1,295
  • Member since Mar '06
  • Pull Your Panties to the side!
« Reply #19 on: Oct 01, 2006, 10:50:34 PM »
 :usa: THANK YOU  :usa:  :bowdown:
toyman1994
  • Male Posts: 59
    • Wheeling Arizona
« Reply #20 on: Oct 01, 2006, 11:00:51 PM »
 :beerchug:
Dude, I like that signiture!!
RynsToy
Last post Aug 25, 2004, 06:02:08 PM
by boney
Last post Apr 24, 2005, 04:42:02 PM
by UNBREAKABLE
Last post Feb 06, 2010, 10:01:38 PM
by rednk1980
Last post Jun 17, 2013, 08:01:40 PM
by Rocksurfer
Last post Jun 04, 2020, 04:15:45 PM
by Slabzilla
