From trig, a 1" drop at the front of a 47" long spring should rotate the axle about 1.2 degrees.Is this a significant differrence? I am curious about the tradeoff between pinion agle and caster. Is 1.2 degrees a problem for pinion angle if you are running dual cases with a longer front d-shaft? It seems like the added caster of a no-drop hanger would be a good thing.
Started by Duffil Engine
Started by 84_yota_4wd Parts Wanted
Started by Destruct O Toyota Tacoma/4Runner/T100/Tundra/FJ Cruiser 1995+
Started by 7Jake Toyota Pickup/4Runner Tech 1979-95
Started by trailcrawler Suspension
