1995 Toyota Ext Cab SAS, NorCal
Started by lckycharm, August 26, 2006, 01:41:33 PM
lckycharm
1995 Toyota 4x4 Ext Cab SAS.NEW PRICE 8,000 obo  8" susp lift on 35x12.5 X-terrains.
3.0L V-6- modified with DOA racing heads (port/polish, valve springs, cams, oversized valves), about 5,000 miles ago , running 200+ hsp.A/C need charged,P/S, T/W. Flowmaster exhaust. No leaks, doesn't burn oil.  Synthetic used only, changed every 3,000 miles.   Have high performance fuel injectors that can be installed (haven't had time to put them in). K&N drop in air filter. New motor mounts installed last week.  New alternator, new power steering
Manual transmission,shifts strong,newer clutch
SAS- front axle from early 80's toyota (pre-85).  4.30 gears front and rear, limited slip rear end.  All Pro Hysteer kit and shock hoops. RS 9000 shocks (5spd adjustment model). Steel braided brake lines.  FJ40 vented rotors. 1.5" wheel spacers on front end.  Springs from s10 with heavy duty overload and 1leaf from k5 blazer.
When I got the truck it had 4" suspension lift.  When added hysteer wouldn't clear pan--> added leaf to front springs. Front currently sits at 7" suspension.  Currently in progress of lifting the rear to a total 8.5" and rebuilding new shackles for front end to match at 8.5".   Currently sits like this- but it will be fixed.
Here is the hysteer installed- hadn't taken it off the jack yet, but this is the only picture I have for now.
35" x 12.50x 15.00  x-terrain tires mounted on aluminum rims + spare tire and rim.  at least 70% tread on mounted tires, 100% on spare
Alpine stereo system ( 200w CD player, 4 pioneer speakers)
P/S, A/C (needs charged), T/W, cluster gage (everything works)
Star style headlights (can't remember name)  (true white light- retail at over $50 a bulb)==> great visual at night- Ive been told they are the brightest you can legally use on the road.
Interior is in good condition.  Standard rip on drivers side seat- not too bad.  Otherwise interior is intact.  Carpet is a little beat up under the mats, but otherwise in good condition.
Front bug guard, wind guards on front and rear windows.   Hylift jack mount on front end
Truck will be completely finished within 2 weeks, unless someone wants to take the lift project over- would be willing to help finish it up (need to have hand surgery so it takes me awhile to finish on my own right now- my wheeling buddies moved away :( ).
Located in Chico,CA- no delivery.  NEW PRICE 8,000 OBO--> Will consider all trades seriously.  Primarily looking for a new full size extra cab truck or a nice car for my wife.  Partial trade for quad/boat/guns considered too.  :D
Have more pictures can send on request
Feel free to call if serious (530)899-9719 or (530)518-6144- have dial up and it takes forever to get onto Pirate so I'm not on much.
Thanks
Chris
lckycharm
Yota87Truck
I would love to buy your truck when it is finished but i couldn't afford it ( just graduated from HS last spring)
lckycharm
redneckcountrygirl4
pirate mafia
that drive shaft angle looks scary, does it even out when it is on all fours?
01 tacoma DD
99 supercharged runner SAS dana 44 ox locker chromos, mc09,snorkel,ARB bumper, 9000winch
sami powerd buggie fox shocks and 4linked all around on toyota axles, 6.5:1 t-case,108" wheelbase 95% tubed,and lots of scares
lckycharm
Decided not to sell after I finished it :D
