2WD and 4WD does it matter?
Started by max, January 11, 2004, 11:08:53 AM
max
If I buy an engine and tranny from 2wd truck can it be used in 4wd truck.  Isn't the transfer case the only thing that would e different on the two trucks.
The tranny is also different, as well as the oil pan and pickup.  change those ane itll wlip right in.
Marlin
Dont forget about the lower u shaped metal water tube that goes around the alternator.
Marlin
84runner
