Ifs whl hubs w/fullfloater?
Started by 4.3 headache, January 10, 2004, 01:38:09 PM
4.3 headache
  I   was looking at Front Range's rear fullfloater/ disc brake conversion and  they 're website says u need 79-85 frt axle hubs and rotors. I'm wondering if anyone out there knows if I canuse 87 ifs hubs on the kit (wheel bearings are the same and they will work w/ strait axle spindles right?) the ifs hubs would widen the rear 3" to equal the front? anyone got any ideas?   :idea:
all i want is a little more than i'll ever get!!
Marlin
If you use IFS hubs with the wider offset, the rotor will not line up with the caliper bracket.
Marlin
4.3 headache
Hi  Marlin! when are they going to open up suprise canyon again ? Sure miss that place. Ran it with you about 3 yrs ago?
also can I run a spacer between rotor & hub? to make it work
tommy h.
frazier park
Marlin
I miss Surpise Cyn most of all. I along with the Bakersfield Trailblazers, now own one acre of land in Sourdough Cyn. :biggthumpup:
I remember running the canyon with you.
You would need about a 5/8"? spacer to line the rotor up.
Give Brian a call at Front Range to make sure--
I dont know why it would not work!
One of these weekends, Im going to hike back up the canyon.
Marlin
Thommy, thanks for the post :beerchug: :beerchug:
84 SR5, Flying J, sun roof-----
