Detroit Easy Locker
Started by HOGAN, January 09, 2004, 06:53:49 PM
HOGAN
I bought an easy locker from a friend, but it doesn't fit in my 87 SA 4Runner.
The box say's it's for a Toyota 4 cylinder 30 spline Part #813A015.
The parts inside are numbered like this
clutch #85002, side gear #85082, spacer #85010.
I think it's for a V6. Any help would be great.
87 Mini Pick -Up
87 SAS 4Runner
62 FJ-40
That is supposed to fit yota 79-85 8 in.  But it is also supposed to fit 87-88 4 pinion gas/turbo/diesel.  From everything I know those two are deffinately not interchangable at all. So I think tractech need some updating to their website!
HOGAN
The diff I was trying to install it in was out of a pre 86. The side gear wouldn't fit in to the carrier. It was to big.
87 Mini Pick -Up
87 SAS 4Runner
62 FJ-40
84runner
You mean the ring gear wouldn't fit on the carrier?
HOGAN
#4
Quote from: 84runner on January 11, 2004, 11:17:14 AM
No it's the outside part of the easy locker, so it goes inside the carrier. It's the part of the locker that goes on the axle.
Here a breakdown.
87 Mini Pick -Up
87 SAS 4Runner
62 FJ-40
89 toy
maybe it's for a 2 wheeldrive?
84runner
