1345 t case little less than 100k on it
Started by yotapride, August 02, 2006, 12:13:54 PM
yotapride
got a 1345 t case that is between 95-100k on it. had it checked out not to longa ago before i was going to use it and everything looked great on the inside. i never used it after i got it cause my project changed plans. i need to sell it now for school supplies. best offer or possibly any offer takes it. i have pics if your interested email me at [email protected] i'm in nebraska 68845. thanks
84_yota_4wd
where u located and would u take 50 if so i wll take it if it will work with my truck
Marlin Crawler
(888) 94-CRAWL / 888-942-7295
yotapride
sent you a pm. think that will barley cover shipping if that. anyone??
yotapride
yotapride
red
what is it out of, the gear ratio, pass or driver side drop, and your location?
read and comment :whip:
USAF EOD tech
yotapride
BORG-WARNER 1345
Type: Chain-driven, aluminum
Low-range ratio: 2.72:1
Lubricant: ATF
Length: (in.): 17.25
Width (in.): 23.0
Height: (in.): 12.0
Used by: Some 1980-to-88 full-size Fords. Holds six pints of Dextron II ATF. This unit can be towed extended distances
because of its built-in pump that channels oil to all necessary bearings.
in kearney nebraska 68845
yotapride
manuel shift to if i did not already say that
yotapride
yotapride
bump.. come on i'll take 75 for it plus shipping anyone
christyle
pretty sure they came in rangers too didnt they?  free bump either way
yotapride
pretty sure on the little older ones in the eighties maybe early 90s not for sure though
yotapride
