Author Topic: scan tool  (Read 1081 times)
ensmyers
  • Turtle Points: -128
  • Member since Dec '04
scan tool
« on: Jul 11, 2006, 06:14:23 AM »
I am getting ready to buy a scan tool but can not find one that does second gen Toyota EFIs and OBDII.  Does anyone have any suggestions?  I am willing to spend up to $800 but don't want to waste my money if I can't check my Yota.  Still trying to sort through all of the different products out there.  Help.
alpha_radiation
  • Turtle Points: 78
  • Member since Apr '05
Re: scan tool
« Reply #1 on: Jul 13, 2006, 05:01:23 PM »
second gen toys 84-89 arn't obdII and don't need a scanner.
What year is your truck?
You put a jumper wire across a terminal and count the number of times the check engine light comes on.
A tacoma would be obdII.
BCD
  • Turtle Points: -79
  • Male Posts: 70
Re: scan tool
« Reply #2 on: Jul 13, 2006, 05:49:23 PM »
'84-'89 4runners are 1st generation and do not use OBDII. I assume you are talking about a '90-'96 2nd gen 'runner, in which case I believe most of them ('92 and newer :headscratch:) do in deed use OBDII. I was under the impression that all scanners were sort of universal and would work with any OBDII capable vehicle, but what do I know, I am still playing with little paper clips under my hood.
-Brian
ensmyers [OP]
Re: scan tool
« Reply #3 on: Jul 17, 2006, 08:08:33 AM »
The 4Runner is an 85, none OBD.  I have been reading the codes using the jumper, but I would like to actually be able to monitor the output of the different sensors.  I want a scanner that will do older Yotas and OBDIIs so that I can do all of my vehicles.
Last post Aug 18, 2005, 11:38:01 PM
by 4DEES
Last post Oct 19, 2007, 12:54:08 PM
by kiyul4130
Last post Nov 21, 2007, 08:06:37 PM
by Mistaken
Last post Mar 17, 2008, 11:19:07 AM
by unclejpl4x4
Last post Mar 09, 2017, 11:58:14 AM
by :)bestgen4runner
