At least in the aftermarket, there is not a difference in 2wd/4wd as far as pumps go. I can't see that(or why) there would be. From what I have here at home, 81-87 carbed trucks use one pump, and 85-87 injected and turbo'd trucks use another. I'll see if I can dig up anything else.
are you sure on this duffil? not sure on the pump capacity or specs, but the 4x2 pump (at least the manual steering) mounts with only 2 bolts, not 3 liek the 4x4..... ill get pictures to back this up if needed
are you talking about a power steering pump or a regular box? my truck is 2wd, and i have manual steering..... yes the 4x4 and 4x2 are different, i dont know by how much, but i do nkow the 2wd mounts to the frame with 2 bolts and the 4x4 mounds with 3 bolts....
Started by burl4x4 Parts Wanted
Started by Jared Engine
Started by Makohon Parts For Sale
Started by TheCookieMonster Toyota Pickup/4Runner Tech 1979-95
Started by 84_Stewart Axle/Differential/Steering
