Author Topic: Factory Toyota Part Numbers  (Read 2527 times)
Weldo
  • Turtle Points: 101
  • Male Posts: 454
  • Member since Jan '05
  • Use what you can, make what you can't.
« on: Jun 10, 2006, 08:03:57 AM »
Anybody know of a place I can find an exploded view of a 22RE.  You know, like the ones they can pull up on the computer at the dealership where all the little parts are labeled 1, 2, 3... etc. and there's a table that shows what part numbers the parts are.  I need a few parts for my engine that only the dealer will probably have and I'd like to have the part numbers handy when I go to buy them.  Thanks.
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
Re: Factory Toyota Part Numbers
« Reply #1 on: Jun 10, 2006, 08:09:32 AM »
what ya need  ??  i might have it
Weldo [OP]
  • Male Posts: 454
« Reply #2 on: Jun 10, 2006, 08:22:37 AM »
Let's see, I need 2 small gaskets and 1 small O-ring for the coolant system.  I need a speedometer gear for 31" tires and a gasket for the rearmost portion of the T-case.  I also need the snap ring for the idler pulley by the PS pump.  And finally I need that square O-ring gasket for the lower half of the throttle body, where the coolant flows through.
Last post Jul 14, 2023, 07:19:41 AM
by Ritchie
Last post Nov 13, 2012, 10:45:41 PM
by NorCalPR
Last post Jul 13, 2009, 02:08:53 PM
by Dr.Maxwe001
Last post Jul 04, 2020, 07:30:57 AM
by Hickory Nut
Last post Feb 13, 2022, 03:08:12 PM
by dweinberg01
