Jet Chip........
Started by 95TacoTruck, December 18, 2003, 10:37:46 PM
95TacoTruck
Just curious if anyone has had a Taco computer upgraded with a JET chip, is it worth the money and does it make a big difference?
95 Tacoma Extra cab, many mods to come........
Dick Foster
yotacrawler85
from what ive heard and seen on other vehicles jet chips make a noticable difference,,, never seen one on a taco though.............
85 cab on a 87 sas frame with 6 inch lift, 15x10 wheels, 34-10.50 swampers, all pro high steer, shock hoops, dual diff guards, in cab roll cage, rancho 5000s, all poly bushings remote diff breathers front and rear recievers, welded rear(4:30's) 22re
Marlin
Unlike American trucks, the prom or chip can not be changed.
It is incorperated into the complete ECM.
Marlin
84runner
Something you have to look out for when putting those chips in is that some burn a signature on your ECM, so it comes up on a scan.  Bad Idea on a new car under warranty and something goes wrong.  And some ECM's will erase some chips after some many start ups
David
Has anyone here tried a jet chip on a chevy 350? If yes, what were the results? I have an 87 chev 4x4 w/350 that could use some additional power. Thanks
95TacoTruck
Not to try to call you a liar Marlin because you are the shiznit, but I am looking and a Performance Products Toyota catalog that sells the JET chip and even explains how you pull your computer and ship it to them and they change it then overnight it back to you.   This is the mod I am referring to.
#7
Just how could Marlin be anywhere close to a liar on that one???  He pointed out that the computer doesnt have a chip, then you come back with "how you pull your computer and ship it to them and they overnight it back to you" What Marlin was saying is Toyota computers dont have chips they have to be modified directly.  Sounds to me like you both said the EXACT same thing!!   :slap:
yotacrawler85
Sorry to steer you down the wrong path Taco :dunno:
95TacoTruck
That's all fine and dandy but in this magazine it is called a "CHIP" replacment so that is why I asked.  I could never call Marlin a Liar,  that is sacreligious or something lol.    I have no answers only questions.
Yeh I get the same mag I think they need to carry stuff for the older stuff... they have gotten better though.
I supose I sounded a bit harsh before sorry bout that, they do make it sound like its a simply job but in the same breath they tell you to send yours in. decieving isnt it?
84runner
It's all a conspiracy to get your computer so they can put a tracking device in it :conf: there all out to get us
95TacoTruck
Lmao it's cool bro  :beerchug: I used to think they needed older stuff too when I had an old truck.  Now that I have a Taco it's cool.
