what sterring box to use
Started by simmont, June 02, 2006, 07:36:54 PM
simmont
what steering box should I use with a gm 10 bolt front rear?  Should I use a toy ifs box or a chevy box?  is the 88? toy 2 wheeler the same box as the ifs.please your :twocents:needed. thanks
89 Single cab, ground up build starting now.
2014 1794 Tundra Crew Max Daily Driver "work truck".
SOLD:85 REG CAB 22R FULL WIDTH 38'S DUAL CASES CUSTOM FRONT WINCH BUMPER CUSTOM CAGE HYDRO ASSIST LOCK ALL AROUND.
SOLD:DALIY DRIVER : 85 RUNNER 22RE 4" LIFT 33"x12.5x15  HI STEER DIFF ARMOR TRUSSED DUAL CASES LOCKED ALL AROUND.
rocblaz
u didnt say if u were using cross over. why using a ten bolt . ifs box out of a 4x4 . with cross over. ten bolt will be ur weak link. better dana 44 or dana 60 .
Ultimate dual mini truck cases! What a test!
CTENG in KS
Use the toy box...all the lines and steering shaft already match up.
IronClad
ignore the 10bolt comment..   personally if i were to do it again i would use a scout 2 box.  pitman arm faces forward so you can get the axle way out in front  and not run out of frame  trying to get the steering box far forward enough to clear the tierod.  the steering arms for these axles are much longer than toyota axle hysteer arms
Annihilation  Fabrication
Do you need a Hammer?
simmont
hey thanks for the input guys.  does anyone know if the 2nd gen two wheel drive toys run the same box as the ifs 4x4. thanks again guys
rocblaz
