1986 Toyota Ext. Cab
Started by seanc, May 31, 2006, 06:53:45 PM
seanc
For Sale: 1986 Toyota Ext. Cab
1986 Toyota Extended Cab. SR5 Grabber Green/Black 2 tone paint
I have had this truck for 2 years and I have built it from the frame up. Every aspect of this truck has been modified and rebuilt for the better.
Modifications:
Suspension:
Waggy springs in rear
15" Poly Performance BBCS Shocks in a custom hoop.
Custom Ext. Shackles
U-bolt flip kit
Toyota Rear/Waggy Front Springs
12" Gas Charged Shocks
Confer Ext. Shackles in front
Braided brake lines f/r
Extended Bump Stops
Trail Gear High Steer with FJ-80 tie rod ends
Drive train:
22re mildly built: LC pistons, 3-angle valve grind, EB Cam, LC header with custom 2.5" exhaust. Runs great starts up warm or cold idles perfect absolutely no problems
W-56 transmission with a great clutch built for the high demands of wheeling
AA dual case adaptor with 2 Toyota top shift t-cases, t-cases has HD shifter springs
Marlin Crawler Dual Case Skid Plate
Custom Long Travel Drivelines Front and Rear
Welded rear end with new brakes
Front axle was rebuilt ~50 miles ago with Long field Super Axles
Interior:
Corbeau Baja SS suspension seats
RCI 4 Point Harnesses
Custom Push Button Start
SR5 Cluster and tilt column
Custom Gauge Panel Displaying Oil Pressure and Water Temperature
Exterior:
Custom Built Exo-Cage built out of HREW 1.5" .120 wall tubing
Louvered Hood
36" Super Swamper SX's
8274 Winch mount built into front skid plate/ bumper
Custom Bobbed Bed
Custom Rock Sliders built out of a combination of 2"x4" 1/4" tubing and 1.5" .120 wall tubing tied into the Exo-Cage
Custom Rear Wrap Around Bumper built out of 2"x2" tubing.
LED Flush Mount Tail Lights in tail gate
Rock Lights on the under carriage
Custom Grabber Green/Black 2 tone paint
Hood Pins
Bed has bed liner sprayed
call me for more info as i do not get on this board much anymore
Sean 425-327-5496
You win some, you lose some.
seanc
84rocktoy
#2
Hello Sean spoke with you today. I sent you an email.
Let me know and we can meet up and work out a deal.
YOUR EMAIL ADDRESS IS NOT WORKING!
Thanks,
Fernando
BECAUSE I CAN
seanc
seanc
here are some pics
