Author Topic: Transmission grinding between 1 & 2  (Read 3565 times)
shiftless89
  • Turtle Points: -277
  • Member since Mar '05
« on: May 26, 2006, 09:22:15 AM »
hmmmmmm  syncros maybe?  I am getting a grinding between first and second only and its intermittent about 50% of the time.
possible problems? solutions?
thanks
Mike
Isn't Colorado that cute little state park in north Texas?
81yota
  • Male Posts: 56
  • Member since Jan '05
Re: Transmission grinding between 1 & 2
« Reply #1 on: May 26, 2006, 03:33:08 PM »
syncros is most likely the problem.  Ive had the same tranny from when my dad originally owned my 81. My reverse always grinds bad, but it still runs prime. I've found if you wait about 1-2 seconds when you put the clutch in to shift it wont grind at all in my situation. Give it a shot.
81yota
Locked F/R
39 TSL'S
5.29's
Dual Cases
Plowking
  • Turtle Points: -75
  • Male Posts: 504
  • Awesome yota
    • Buy me a drink
« Reply #2 on: May 26, 2006, 07:05:06 PM »
 The grear grind becomes something you learn to control with your trans ( baby or rebuild) some times doubleshifting or even pausing while holding the clutch down between shifts helps\, or know when the gears mesh at what rpm level per gear. On the other hand make sure your oil level is high enough for trans   good luck :blah:
2008 Dodge Diesel  (Cummins Rule)
6.7 manual quad 8 foot bed H&S delete, banks air box
93 yota 3.0 locked up...
2004 Yamaha Raptor 660R
Willy Mammoth
  • Male Posts: 4,252
  • Member since Nov '04
« Reply #3 on: May 27, 2006, 04:52:03 AM »
Reverse will grind because there is no syncro. The pilot bearing may also be getting tight causing a drag on the input shaft.
Try putting it in 1st gear before going into reverse. This will stop the trans from spinning before putting it into gear.
On the second gear grinding, the 2nd gear is usually the first to have problems, speed shifting and down shifting causing it to get stretched out.
You could try some thicker oil to see if it will help, but first just try changing the oil if it hasn't been changed in a while.
If the oil won't help you will need new syncros.
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
« Reply #4 on: May 27, 2006, 07:40:01 AM »
Mike i thought you had a auto :eek:
toyo487
  • Turtle Points: 162
  • Male Posts: 493
  • Member since Oct '05
  • Living life in Gods county
« Reply #5 on: May 27, 2006, 08:28:13 AM »
Mine does the same thing. (grind between 1st and 2nd)  I just shift slow from 1st into 2nd and I usually don't have any problems.  Rebuilding is your best bet, but if you cant afford it right now then just take your time when shifting between those gears.
1986 Toyota 4Runner 22re 5spd transmission and dual transfer cases (4.7’s in the rear). E-lockers front and rear.
2005 GMC Sierra diesel, compound turbo setup to pull.
   God gave all people talents but the only one who can find them is you.
shiftless89 [OP]
« Reply #6 on: May 29, 2006, 05:47:03 AM »
nope V6 5spd!
Fluid,  I put fresh synthetic in it about a year ago, maybe it scrubbed all the sludge out of the bearings/syncros, now they are loose? ( not sure of the trucks history for the first 90k of its life)   I'll try the heavier oil first then save my pennies for one of marlins units with a lower gear set!
81yoter
  • Male Posts: 24
  • Member since Sep '05
« Reply #7 on: May 29, 2006, 10:50:07 AM »
i love the shifting problems from shiftless89
oxymoron anyone?
Totally Stock And Lovin It!
blackdiamond
  • Turtle Points: 1174
  • Male Posts: 5,058
  • Member since Dec '03
  • Crawlin with Marlin
« Reply #8 on: May 29, 2006, 11:02:37 AM »
nope V6 5spd!
I have heard that Toyota transmission were designed for GL-4 gear oil and that GL-5 can be too "slick" for the syncros.  Redline MT90 claims to have the right amount of friction for the syncros.
http://www.redlineoil.com/products_gearlubricants.asp?pvID=74&prodID=57&subcatID=18
I have read that using Redline gets rid of the "cold" shift issues in the transmissions as well.  Redline is expensive, so I am considering trying to find a dino GL-4 (not GL-5) in the future and see if it helps my 3-2 downshift and 1-2 upshift.
Hopefully someone else knows more about this?  :dunno:
shiftless89 [OP]
« Reply #9 on: May 29, 2006, 11:13:33 AM »
oxymoron anyone?
FUNNY! :) :) :) I hadn't even thought of it.  my screen name is from when I raced MTB's i raced singlespeed bikes..   therefore no shifting!  I guess its kharma that my name is proving itself
shiftless89 [OP]
« Reply #10 on: Jun 14, 2006, 08:46:49 AM »
I swapped the synthetic for some good ole liquid dinasour this weekend.  My grinding has all but disapeared.  Shifting is not as smooth, but hey its a 4x4 right? its not a BMW.  Still saving my  :twocents: for a  :turtle: tranny
Last post Sep 26, 2005, 09:01:03 PM
by ksmith
Last post Nov 03, 2005, 03:48:30 PM
by dentedfender
Last post Nov 13, 2006, 08:53:58 AM
by All_Set
Last post Apr 28, 2007, 04:37:05 AM
by fullthrottle
Last post Apr 29, 2008, 08:37:45 PM
by SolidAxle
