For Sale
Pakage deal
85 Toyota Front housing modified by welderboy to accept E Locker.
Modified housing link what has to be done.
2001 4.56 Toyota E Locker with low miles on it.
![](http://www.marlincrawler.com/images/hpele_250.jpg)
Electric Lockers are factory Toyota parts based on the beefy V6 style 3rd member. Electric Lockers require modification to your axle housing as seen above.
Electric Locker Control Kit.
![](http://www.inchwormgear.com/store/product_thumb.php?img=images/Control%20Kit.JPG&w=150&h=112)
Comes with electric control Kit he electric locker control kit contains everything you need to engage and disengage your electric locker. The switch, wires, fuse, resistor, connectors, and zip ties are all included with detailed instructions. Factory harness (available separately) is required to plug into the diff.
Axle has Sky Truss on it. ( No Toyota Writing ) Below pic has the toyota engraved.
Sky's front upper axle truss helps strengthen the Toyota stamped steel axle housing. By positioning the truss on the top of the axle, you don't loose any ground clearance, compared to bulky under the diff style truss'. Constructed of 1/8th inch steel, formed and laser cut, with the Toyota logo. No grinding or fitting is needed, this truss fits exactly like it was a factory part!
Also has 8 inch Pipe cap on the front of the diff to pertect the front of the Diff.
Comes with extra motor for the elocker.
This only come with the above mentioned and doesn't come with birfs or inners !
Asking $ 700
Located in El Dorado Hills
Thx
Dave
